First post, by Daninthemix
DgVoodoo doesn't seem to work properly with Downtown Run - I get the DgVoodoo watermark, but the resolution isn't increased.
Reply 1 of 5, by ZellSF
Resolution forcing is an extra, not something that can be relied on, not the main function of dgVoodoo. So saying dgVoodoo doesn't work would be incorrect.
The game calls USER32.dll/ChangeDisplaySettingsA to change resolution, which isn't a DirectDraw/Direct3D function so dgVoodoo being strictly a wrapper doesn't stop it. But:
1) Why not just set your resolution in Downtown Run\data\save\Main.cfg ?
2) If UI scaling is a problem, why not use OpenGL mode and use Peixoto's patches (that aren't strictly DirectDraw/Direct3D9 wrappers) to force resolution? This seems to give pretty good results (960x720 forced to 4K):
577.74 KiB
Reply 2 of 5, by Daninthemix
ZellSF wrote on 2021-06-20, 17:46:
Resolution forcing is an extra, not something that can be relied on, not the main function of dgVoodoo. So saying dgVoodoo doesn […]
Thankyou - I'll try the latter (setting 3840 x 2160 in Main.cfg didn't do anything).
Reply 3 of 5, by ZellSF
Daninthemix wrote on 2021-06-20, 19:43:
That definitely should have done something.
Possibly you did something wrong, you went into the settings afterwards and saved them or maybe it got virtualized into %LOCALAPPDATA%\VirtualStore
But there isn't a proper widescreen patch for this game; setting it to 3840x2160 means you will be able to view less vertically.
Reply 4 of 5, by Daninthemix
ZellSF wrote on 2021-06-21, 22:34:
That definitely should have done something. […]
I got it working by setting the game to windowed, setting DgVoodoo to fullscreen with 'center app window'. You're right - widescreen is unusable. 1600 x 1200 works though.
Reply 5 of 5, by Dege
You can also try to set GeneralExt\DesktopResolution to your expected desktop resolution which affects the calculation of dynamic resolutions.
That option is for cases like with this game, when the game pre-sets the desktop resolution to the one it expects before initializing DDraw/D3D.
I didn't try if it works for this game though.
