First post, by Dhigan
Hello, would someone please post a link or upload to archive.org or (better) vogons library the install CD for Philips Rhythmic Edge PSC703 ?
https://www.tomshardware.com/reviews/a-soundb … ter,368-15.html
I am looking for the DOS drivers and the Yamaha SoftSynthesizer S-YXG50 as the links posted by swaaye (in 2009) are dead.
Philips Rhythmic Edge PSC703 - Is it supposed to sound THIS bad?
Thanks in advance.
Win 3.1 : HP Omnibook 425 + Toshiba T2130CT
Win 9x : Dell Latitude Cpx H500GT + Dell GX1
Win XP64 : Asus P5B Xeon
Reply 1 of 6, by pc-sound-legacy
DOS drivers might be found or installed with the win95 drivers package.
https://www.philips.de/c-p/PSC703_00/-
Yamaha SYXG can be found separately and sometimes it is provided with games (Final Fantasy VII / VIII for PC as an example if I remember right)
Reply 2 of 6, by Dhigan
Big thank you !
The DOS driver is also on this page ... Found working XG drivers elsewhere (legacy edition). If someone has the install CD, I am still interested.
Reply 3 of 6, by Hatröss
This morning I found my CD and ISOed it using
mkisofs -R -J -o c:/tmp/rhythmic.iso .
which makes a 243 MB iso. I then RARed it yielding, to my surprise, a file of only 147 MB.
Now I need to know where to upload it to. It can (eventually) end up on vogonsdriver as far as I'm concerned.
Reply 4 of 6, by Mr.Sanya
Hatröss wrote on 2022-07-27, 11:01:
This morning I found my CD and ISOed it using […]
Hi! May be you can upload this ISO to Google Drive? I have two of these cards, but i can't use them neither in Win9x, nor in DOS. Thanks.
Reply 5 of 6, by Hatröss
Love to see those cards but they have Thunderbird 128 chips, not Thunderbird Avenger. The ISO won't help. The concerning pages at philips.nl died not long ago but the links to drivers are still good. Try these for your cards:
VXD
https://www.download.p4c.philips.com/files/p/ … _00_d98_eng.exe
WDM
https://www.download.p4c.philips.com/files/p/ … _00_d9s_eng.exe
Change the 3s to 5s in the links to get the Seismic equivalents.
Reply 6 of 6, by mockingbird
Mr.Sanya wrote on 2024-03-16, 12:24:
605.65 KiB
Specifically with the VLSI ThunderBird128 cards with the large chip pictured above, has anyone got PC/PCI working on it? I soldered on a header and attached it to my board, but I don't see any option in SB_INIT.EXE that allows you to specify that.
It seems like a very decent card (PC/PCI, Wavetable header) which would theoretically work quite well in DOS if only SBLINK could be made to work. The documentation states it supports DDMA, PC/PCI (SBLINK), and something called "LAM"...
Here is the output of SB_INIT.EXE when run with the ? or h parameter:
SB_INIT.EXE V6.32 (C)1992-1999 VLSI Technology, Inc. VLSI Audio Initialization Utility
USAGE: SB_INIT.EXE [options]
AUBASE=X: Set audio base to [X] (hex) [Def: Do Not Change]
GMBASE=X: Set game base to [X] (hex) [Def: 0x0200]
SBBASE=X: Set sound blaster base to [X] (hex) [Def: 0x0220]
MDBASE=X: Set midi base to [X] (hex) [Def: 0x0330]
ALBASE=X: Set adlib base to [X] (hex) [Def: 0x0388]
NO_BASES: Do not initialize bases [Def: Initialize]
DISABLE_GAME: Disable the game port [Def: Enabled]
DMAA=X: Set DMA channel A to [X] (dec) [Def: 1]
DMAB=X: Set DMA channel B to [X] (dec) [Def: Unassigned]
NO_DMA: Do not initialize DMA channel [Def: Initialize]
WS=X: Set DMA WaitStates to [X] (dec) [Def: 0]
NO_WS: Do not initialize waitstates [Def: Initialize]
INT=X: Set interrupt to [X] (dec) [Def: 5]
NO_INT: Do not initialize interrupt [Def: Initialize]
NO_STEER: Do not steer PCIINT to IRQ [Def: Steer Interrupt]
STEER_ONLY: Steer PCIINT to IRQ ONLY [Def: Steer AND Init]
DSPFREQ=X: Set DSP PLL Frequency to [X] (dec) [Def: External Clock]
NO_DSP_FREQ: Do not initialize DSP PLL [Def: Initialize]
EXTCLK: Use external clock for DSP, not PLL [Def: Rev Dependent]
CODECFREQ=X: Set CODEC PLL Frequency to [X] (dec) [Def: 24545500Hz]
NO_CODEC_FREQ: Do not initialize CODEC PLL [Def: Initialize]
DLCODE=f: Download file [f] DSP CODE RAM [Def: VSONG.COD]
NO_DLCODE: Do NOT download to DSP CODE RAM [Def: Download]
DLPATCHES=f: Download file [f] DSP PATCHES [Def: VPATCHES.COD]
NO_DLPATCHES: Do NOT download to DSP PATCHES [Def: Download]
DLDATA=f: Download file [f] DSP DATA RAM [Def: VDATA.COD]
NO_DLDATA: Do NOT download to DSP DATA RAM [Def: Download]
NO_DOWNLOAD: Do not download any files [Def: Download ALL]
NO_DSP: Do not initialize DSP (leave in float) [Def: Initialize]
ROM90: Spec 90ns WaveTable ROM [Def: 120ns]
ROM120: Spec 120ns WaveTable ROM [Def: 120ns]
ROM150: Spec 150ns WaveTable ROM [Def: 120ns]
NO_ROM: Do not initialize WaveTable ROM Speed [Def: Initialize]
CODEROM: Specify code ROM, disable CODE dload [Def: Code RAM]
SRAM16K: Specify 16K DATA RAM [Def: 32K DATA RAM]
NO_SB: Do not touch any SoundBlaster Regs [Def: Touch SB]
RECORD_OUTPUT: Enable Output Recording via HDI
AC97_OUTPUT: Enable AC97 Output
MDAC_OUTPUT: Enable MDAC Output
QUAD_OUTPUT: Enable Quad Output
DEBUG: Enable Debug Mode
QUIET: Enable Quiet Mode
VERBOSE: Enable Verbose Mode
H or ?: This Menu
(Decommissioned:)
