Illegal command: win
First post, by cort13
I've checked the boards for a hour or so and I can't find this mentioned anywhere but I apologize if its redundant.
Trying to install some educational software called Ultimate Speed Reader and I'm getting the error : Illegal command: win
Here is what I'm doing:
starting up Dosbox
mount D D:\ -t cdrom -label ULTIMSR -ioctl
mount C C:\olddos
d:
then at the d: prompt, i type "setup.exe"
After I hit enter, Dosbox then shows
d:\win SETUP.EXE
Illegal command: win.
I've tried mounting without the -label, as well as without the \olddos and I get the same result.
Many thanks in advance for the help.
EDIT: other relevant factors possibly, I'm running Windows XP and I'm trying to install the program as opposed to running it (which I will do once its installed).
Reply 1 of 3, by eL_PuSHeR
win SETUP.EXE
Seems like very suspicious to me. Is it a Win NE application by chance? 😕
Reply 2 of 3, by DosFreak
I suppose it's possible that setup.exe is a Windows executable. IIRC, Speed Reader comes in Windows 3.1/95, DOS versions. Don't know what the CD looks like but look around for an Install.exe or somesuch.
Make your games work offline
Reply 3 of 3, by cort13
There is no install.exe anywhere on the CD, and upon further examination, it seems pretty likely that it is a Windows executable. Yet another reason for me to be disgusted with Microsoft.
Thanks for the help guys.
