First post, by TimWolf
Looking to play Odyssey 2 on a classic computer. Apparently the two emulators that can do this with Dos are 02em and mess. What are the minimum system requirements that will get me where I want to be with decent performance, and version? I see 1.16 and .9 online for o2em for example but they dont give specs. Just say works on dos. Thank you in advance.
Reply 1 of 1, by hail-to-the-ryzen
A Pentium 1 should work for 1.16. It is also possible a fast 486 will run it, too. I believe mess is based on o2em and o2em is recommended.
