First post, by RiP
Can someone identify these motherboard and graphic card? 🤔
    1.45 MiB
    1.56 MiB
Reply 1 of 15, by weedeewee
google says this for the vga : LSI Logic L4A0447 VC-004 Gemini, FCC-ID: A3LGTI-VGA1, GTI-VGA Bios, ISA 1990
mainboard : pc-chips m912 v1.7
Do not ask Why !
Reply 2 of 15, by Deksor
The video card seems to be made by Samsung (according to the FCC-ID : A3LGTI-VGA1)
And it's a VGA card.
Reply 3 of 15, by weedeewee
Deksor wrote on 2021-07-20, 17:18:
considering the 15 pin and 9pin connector including the dipswitches & onboard crystals, I wouldn't be surprised if this card also does MDA, CGA & EGA.
Do not ask Why !
Reply 5 of 15, by weedeewee
yeah, that kinda figured since nothing relevant shows up on google.
What monitor do you have connected right now? If I were trying to get this card working, I'd hook up a nice multisync vga monitor up to it, then try different dip switch settings (there's only 64 combinations 🤣 )
Allthough since I have an oscilloscope, measuring the signals on the appropriate pins, either on the 9 or 15 pin connector would give a clear sign of either the card working and what resolution it's trying to output.
Do not ask Why !
Reply 7 of 15, by Tiido
I am actually exploring that sort of idea : http://www.tmeeco.eu/HARDWARE/CacheModules2.jpg
Reply 9 of 15, by rmay635703
RiP wrote on 2021-07-20, 21:04:
weedeewee wrote on 2021-07-20, 18:43:
Nooo 🤣 😑
I don't have any CRT monitor.
I had a vga card identical to yours, I ended up scrapping it for Ram and oscillators after it failed.
From what I could tell it behaved more like a first Gen vga card (1987/88) than a card from 1990, very slow.
Best leave it in a 286 system and get a faster western digital VLB SVGA for your local bus
Reply 10 of 15, by jakethompson1
Nooo 🤣 😑
If you google L4A0447 you might find pictures of a working card, like this one: https://www.worthpoint.com/worthopedia/286-cl … uter-3832702488
So maybe you can copy the jumper settings.
Reply 11 of 15, by weedeewee
seems like only two jumpers and one dipswitch are different.
Do not ask Why !
Reply 12 of 15, by 1nanoprobe
I have the exact same motherboard, but I never got mine to work. It's an Amptron DX-6900.
Jumper settings are here:
https://stason.org/TULARC/pc/motherboards/A/A … 0-VER-1-75.html
Reply 13 of 15, by RiP
jakethompson1 wrote on 2021-07-20, 21:26:
Sadly, that jumper setting didn't work too 🙁
Reply 14 of 15, by Horun
Did you try this jumper+switch setting: http://www.vgamuseum.info/images/palcal/gemin … eminivc004b.jpg
or is that same as the worthpoint pic ? hard for me to see 🙁
Reply 15 of 15, by RiP
Horun wrote on 2021-07-24, 21:21:
It didn't work too 🙁
