Rust repairs
First post, by zapbuzz
I have just got this SCSI card on order coming to me with rust on it and I need to know how I can remove it. Also, anyone know where I can get drivers for 98SE and XP?
    196.34 KiB
    253.57 KiB
    149.78 KiB
Reply 2 of 4, by Mister Xiado
Many of the restoration crew on Youtube go into great detail on removing rust from small metal items, like die-cast cars and such, most frequently with store-bought rust-removal chemicals. Some also use electroplating to put zinc on the items to prevent them from rusting again.
Reply 3 of 4, by zapbuzz
Found drivers for it but not for xp or above, so, i'm gonna try use my pci adaptec card its an AHA-2940-UWP1 to run my cd burner when i get it.
It runs on anything microsoft up to vista but only 32bit OS.
Then, if the burner works I will have a burner from the post - burn hole era as it has 2mb buffer and burns at 4x 🤣 but slow burners do a good job; YAMAHA looks good on retro the white and beige combination reminds me not all beige are the dirty ones 😀
    150.38 KiB
    90.1 KiB
    104.84 KiB
Reply 4 of 4, by zapbuzz
So I have decided to use a dremil style approach but not with abrasive attachment but a buff tool with cream polish just to clean off the rough (toothpaste can but i will use car) and then I shal give it the rust converter treatment.
When it is done it will not look rusted but really tiny pit marks will tell the metal kind of lost a little "meat"
Finally, I may seal it with spray laquer just to stop it rusting again.
