Pentium 75-100 Mhz
First post, by millQ
Anyone have a Pentium 75 MHZ or 100Mhz that can run a 'bench' progam for me in DOS (or Windows ) (is 16bit )?
I only have a Cyrix 5x86 (slow FPU) and need something faster to test the program I made vs a 68060 75MHz Motorola CPU
It will take less than 10 seconds.
anyone?
Reply 1 of 23, by Caluser2000
I've got an AIO Compaq P1 75mhz out in the shed I can give a go on.
Reply 2 of 23, by millQ
ok, Great!
I used 7 zip to compress.If you want some other formatI I can upload it (exe is only 28kb when unzipped)
I need the number (seconds) when the program has completed or if you take screen shot.
https://mega.nz/file/XoYVFAaY#YjB2u8qe-vhyVYJ … ZZOISf3D2VZZcO4
and Thanks!
Reply 3 of 23, by Kalle
Would a P90 be OK, too?
    56.29 KiB
    53.45 KiB
Reply 4 of 23, by Caluser2000
Here you go:
    583.09 KiB
    508.55 KiB
Reply 5 of 23, by millQ
90Mhz is OK. Thanks 😀
Can you see if any of these are faster on your INTEL (less time) ?
FPU512AA
FPU512AB
FPU512AC
FPU512AD
(C was the fastest for me. It gave my 100 MHz Cyrix CPU a small boost (from 3.1 sec to 2.5 sec..still did not beat your Intel CPU). D was very slow took 20 seconds!)
https://mega.nz/file/X5RxhQjS#ciqEAECOG7QlpwT … MkwVr4EY2SqSv-s
Reply 8 of 23, by Doornkaat
Kalle wrote on 2021-07-27, 22:32:
You can usually also jumper a P90 to run at 75MHz, 100, 120 and often 133MHz. If you want a bit more power from that machine you can try it. 😎
Reply 9 of 23, by millQ
mwdmeyer wrote on 2021-07-28, 04:24:
I'm interested, what are you writing?
I am testing FPU performance (Intel vs Motorola). Motorola at the time was supposedly better at FPU on the 68060 CPU' vs Intel.
The 75Mhz 68060 CPU( 1.648 seconds) is currently as fast as Kalle's 90MHz Intel in these test's.
Reply 10 of 23, by millQ
Kalle wrote on 2021-07-28, 05:40:
They were all slower on the P90. The overall times were like this: […]
A: 2.087000 to 2.143000
B: 2.142000
C: 1.867000
D: 12.633000 (yes, that long)
ok , thanks
So Cyrix and Intel behave similar. A, B, D version was also slower than BC version for me.
I will see if it is possible to make the C version a little faster than BC version on Intel too
Reply 13 of 23, by Caluser2000
Pics of the last two tests. Same P75 system:
    508.11 KiB
    626.21 KiB
Reply 16 of 23, by Caluser2000
Pentium 1s were well known for their better fpu perforence compared to competing cpus at the time..😉
Reply 18 of 23, by Caluser2000
I'll give them a shot on one of my 486DX2/66 or 486DX2/50 and see how they go...
Reply 19 of 23, by millQ
Caluser2000 wrote on 2021-07-31, 03:28:
ok 😀
Just in case P3/P5 don't work..
(Don't know if this one work on 486..but better than nothing)
FPU486
https://mega.nz/file/qkAWCJqQ#YQHWtWTee6Jw8bg … Z9WsZBXar7epIqA
