First post, by perhenden
I've got a Asus ISA-486sv2 rev 3.1, with SiS 85C461 chipset, AMI bios 1993 and Intel/AMI MEGA-KB-H-WP keyboard controller.
It fails to boot. I've debugged it, but wasn't able to fix the issue, so I ask the Vogons 😀
I've tried reseating RAM and all chips, another CPU, other RAM, with and without a display adapter, without cache, and verified jumper settings.
There was a small battery leak, but I don't see any bad traces. The keyboard connector was damaged by the battery leak, I replaced it with an identical one. There is connectivity from all pins of the keyboard connector to the keyboard controller.
The last bios post codes are 12 and 13 in every case. When I remove the RAM, the speaker beeps, and different codes show.
My theory is that is does not reach step 14 "keyboard kontroller OK", because the keyboard controller is bad. Got any other ideas?
I can't find the datasheet for that keyboard controller. Do you know of any compatible controllers I can buy (for cheap)?
Motherboard specs:
http://www.win3x.org/uh19/motherboard/show/822
