First post, by Bhuthogg
I'm still running an original ide in my p1 and it's started the clicking noise,
So just before I say farewell is there a recommendation for drivers backup tool ? Save me the long haul of hunting them all out when I replace the HDD
Thanks
Reply 2 of 5, by chinny22
Yeh much easier backing up the entire drive then finding a tool to extract drivers already installed into windows. Original P1 HDD, I'm guessing the entire HDD is around the 8GB mark?
9x isn't anything fancy, you can use a image program if you wish or simply copy the entire disk to a separate disk you'll need to run the sys command on the new disk to make it bootable first.
But unless you have any rare bits of hardware drivers are pretty easy to find these days as well.
Reply 3 of 5, by Bhuthogg
I'll just back the entire drive thanks guys that seems the most sensible option
Reply 4 of 5, by zapbuzz
- norton ghost
-powerquest disk image
-symantec disk image
a few disk imaging tools
also nuts n bolts 98 disk image
point being cloning onto another disk from a disk means no drivers lost.
.... oh spinrite 5 perfect for your disk to rejouvinate it maybe bring it back from extinction
they all come in dos floppy form maybe even create cdroms
I could make them if asked nicely 😀 ... not norton ghost don't like ghosts!
Reply 5 of 5, by LieboOSBA
Could you not put the drive in a newer machine and boot CloneZilla from CD/USB and then clone the drive to a working one (maybe even a CF card in an IDE adapter?)
LBX Computers
