First post, by Chadti99
Can anyone confirm if this card supports the VESA 2.0 resolutions for Duke 3D out of the box, in dos?
The Riva 128 PCI does for sure but would def like to try this card out. I actually received one but it was DOA unfortunately.
Reply 1 of 10, by the3dfxdude
Do you get beeps on power on indicating a failure to detect the card? Or just a black screen, and normal post?
The card might be fine. See here:
Matrox Millennium G200 "No Signal" Issues
You should be able to get VESA compatibility.
Reply 2 of 10, by The Serpent Rider
Matrox G200 support all common VESA 2.0 resolutions up to 1280x1024.
Reply 3 of 10, by Chadti99
the3dfxdude wrote on 2021-08-04, 00:11:
Do you get beeps on power on indicating a failure to detect the card? Or just a black screen, and normal post? […]
This is the greatest internet community out there. The bios recovery tool has me posting with video! Thank you!
Reply 4 of 10, by Chadti99
The Serpent Rider wrote on 2021-08-04, 02:01:
Thanks for the info Serpent, Duke3D must be really picky. It’s kicking back to dos stating “VESA driver for 320*400 not found/supported.” Any resolution under 640 in VESA mode, but 640x480 works though.
Reply 5 of 10, by The Serpent Rider
Matrox cards never supported these out of the box, but G200 has unofficial TSR which adds uncommon res modes.
Reply 6 of 10, by treeman
I remember running univbe.exe to get svga working on cards that didn't work on duke3d
Reply 7 of 10, by Chadti99
The Serpent Rider wrote on 2021-08-04, 04:24:
Got it, do you know of any cards that do? Besides the Riva 128?
Reply 8 of 10, by Gmlb256
Chadti99 wrote on 2021-08-04, 11:37:
The S3 video cards can work with VESA resolutions lower than 640 without UniVBE, however the most common ones uses VESA 1.2 BIOS and may require to use the S3VBE20 TSR to bring VESA 2.0 support.
Reply 9 of 10, by Chadti99
Gmlb256 wrote on 2021-08-04, 19:16:
Okay, I’ll need to try one for sure. I just tried a Banshee and it doesn’t support these resolutions, for Duke3D, out of the box either.
Reply 10 of 10, by Chadti99
Thanks Serpent, I was able to run Duke 3D at 320*400 using Gx00VBE on the G200.
