First post, by elsegundo
Hey Ive got a socket 7 pentium 200
with ati video expression drivers..
says 800 x 600 is the most i can get with full 32 bit color
Reply 1 of 7, by darry
How much video RAM does that emulated ATI video card have ?
800x600 in 32-bit color requires almost 2 Megabytes of video RAM , whereas 1024x768 in 32-bit color requires 3 Megabytes of video RAM .
Reply 2 of 7, by elsegundo
darry wrote on 2021-08-04, 04:24:
4 megabytes
Reply 3 of 7, by darry
elsegundo wrote on 2021-08-04, 05:50:
4 megabytes
That is a good start .
Now why are you using the ATI Video Xpression drivers ?
The ATI Video Xpression tops off at 2MB video RAM http://web.archive.org/web/19970404094223/htt … ics/videxp.html and uses a mach64 VT2 chip http://www.vgamuseum.info/index.php/cpu/item/ … -ati-mach64-vt2 . Consequently drivers meant for that card model are likely limited to recognizing 2MB of video RAM at most .
EDIT : Also, apparently I misread, the Mach64 VT2 does exist in a 4MB variant . You should still used the Mach 64 GX driver if that is what PCEM emulates .
AFAIK, PCEM v15 emulates an ATI Graphics Pro Turbo with a Mach64 GX chip, which can have up to 4MB of RAM http://www.vgamuseum.info/index.php/cpu/item/ … 7-ati-mach64-gx
IMHO, you should consider consider using drivers for that card model instead .
Reply 4 of 7, by elsegundo
darry wrote on 2021-08-04, 06:07:
That is a good start . […]
4 megabytes
ok I switched it and downloaded "ATI Garphics Pro Turbo etc" is that the right drivers for windows?
Reply 5 of 7, by darry
elsegundo wrote on 2021-08-04, 06:22:
4 megabytes
The drivers for Mach64 GX based products can be found here : https://web.archive.org/web/19991013022230/ht … mach64GXCT.html
Reply 6 of 7, by darry
Windows 98 SE includes drivers for the Rage Graphics Pro Turbo and they seem to work fine at 1024x768 in 32-bit , for example .
If you need drivers for an older Windows OS, the link I provided previously should have them .
25.18 KiB
Reply 7 of 7, by darry
The Windows 95 driver on the archived ATI site is corrupted .
Here is a working copy
64w95303.exe
1.5 MiB
60 downloads
