First post, by Akuma
Hi,
There is a file called TIME.PRG on the disk/cd-rom, which is actually a ZIP file.
It contains a assembly demo from 1993, that entered the compo at the time.
CASCADA presents: HexAppeal 😁
Since the file is free to distribute according to the text file in the zip, I attached it below.
I liked the music, so I stripped the MOD file from the DEMO, also attached it below
The demo has some problems with DOSBox and runs kinda weird. Not bad, but not good either.
    LIBERTINE_SONG.ZIP
    134.66 KiB
    53 downloads
    TIME.ZIP
    331 KiB
    54 downloads
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
https://www.pouet.net/prod.php?which=1157
Use GUS for sound. The demo tweaks the overscan area for ~60 Hz refresh instead of the usual 70 Hz, which throws off the aspect correction a bit in DOSBox.
