XYZZY
First post, by DosFreak
http://www.rickadams.org/adventure/c_xyzzy.html
Make your games work offline
Reply 1 of 2, by eL_PuSHeR
Most curious. Didn't know the "XYZZY" string was so widely spreaded around the world... 😎
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by MiniMax
Rank Moderator
Moderator
<rant mode="useless">
The page wrote:
'Nothing happens...'
Data General's AOS/VS operating system had an undocumented command named "XYZZY." In the original 16-bit version, the response was: "Nothing happens." In a later 32-bit version, this was amended to: "Twice as much nothing happens."
Well, it was not the operating system per se that had a hidden command - it was the CLI (Command Line Interpreter).
Like with most CLI's you could create your own command scripts, but you could not override the built-in commands (likes FILES), unless you explicitely wrote out the full name, e.g. FILES.CLI.
Except for the hidden built-in XYZZY command where the CLI would first look for script file called XYZZY.CLI, and only then reply with the "Nothing happens..." message.
_________________
