First post, by Moogle!
Which is better: Ark1000VL or Trio64?
Reply 1 of 5, by TheMobRules
In DOS benchmarks, the Ark is slightly faster in VGA mode while the Trio should be a bit faster in VESA modes. I don't think you're going to notice any differences in gaming though.
In Windows I believe the Trio is considerably better when it comes to accelerated performance.
Personally I'd go with the Trio64.
Reply 2 of 5, by The Serpent Rider
ARK is useful in only one discipline - timedemo Doom for fancy numbers. Everything else is better on at least tied with S3 Trio 64, because you can boost S3 cards VGA and VESA performance with additional tweaking.
Reply 5 of 5, by Gmlb256
S3 Trio64. The VESA compatibility on those chips are better and it can be extended, and for Windows it has good GDI acceleration performance.
