First post, by stege
Have tried several other packet drivers (8139 and older) but without success. Can ping the outside world but there's not really much else I can do (telnet, ftp, etc) without a functional packet driver.
Any suggestions? Have found nothing on the webs on the 8168 (HP ThinClient T420)
Thanks.
127.58 KiB
121.59 KiB
102.14 KiB
115.59 KiB
Miss the Monkey Island days, the Space Quest days, even The Longest Journey days.
Reply 1 of 6, by ruthan
Something from here could help..
Dos / Dosbox / Dos VMs ethernet / filesharing /network Dos to Win98-Win10 -WIP, help needed especially from Win admins..
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 3 of 6, by Caluser2000
vladimiro wrote on 2021-08-16, 01:19:
looks good by the readme.txt
Reply 4 of 6, by mike_canada
stege wrote on 2021-08-14, 06:21:
If pinging the world gives you success then your software probably just does not want to work. Luckily a guy who also visits here created a whole collection of internet tools (which include an FTP and WEB server) that work with DOS. He mentioned he tested his software on very old machines so his software might work for your needs. All you really need to use his software is your packet driver installed (which you did already), and setup a configuration as per mTCP's standards.
He has the software, source code, and documentation all for free. Go to:
https://www.brutman.com/mTCP/
Reply 5 of 6, by mbbrutman
It's difficult to make a packet driver appear out of thin air for hardware that doesn't have one. But you might be able to make it work by using a "shim" driver.
A shim driver allows you to use an NDIS or ODI driver as a packet driver. You install the NDIS or ODI driver, and then the shim driver. The shim driver translates the NDIS or ODI driver calls, giving the appearance of a native packet driver for your hardware.
See this page for some packet driver shims: http://www.shikadi.net/network/ .
Mike
Reply 6 of 6, by stege
Thank you gentlemen.
I'm already using the mTCP, brilliant piece of code. The packet driver @Vladimiro and @Caluser2000 suggested only appears to work, giving a nice status message when launched but nothing works afterwords (net wise), not even ping.
I'll try mr mbbrutman's approach and give it a go.
I'll report back asap.
Thank you again!
