First post, by Nexxen
Hello most lovely people,
I have this board and it has a strange behaviour.
A little history,
I thought it had died and had it lay around for almost a decade. Yesterday I decided to give it a new round of diagnostic work and it actually POSTed and works perfectly well.
I managed that by switching on the PSU and powering on the board many times in a row.
My idea is that it needs to fill some caps up and as soon as it's stable enough it starts up.
Diag card shows "RESET" led always on when it doesn't POST.
There are strange things though, like caps giving continuity even when powered on.
I'm on the recap-it-all plan.
Probably there are leaks to ground from failing caps, that I can't locate (no obvious bulges or bottom downs); the few I desoldered weren't shorting. But maybe it's about time I buy a tester.
The nice thing is that as long as you don't let too much time pass between power ons, the board POSTs fine and is stable enough to load Ubuntu 7 and 8 (I haven't tried Windows yet).
I've read this pattern happen to others before, but I don't know if this was the reason every time.
Thanks for any two cents.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 1 of 18, by bloodem
I can highly recommend this (pretty cheap) device: https://www.ebay.com/itm/324672136249 (no, I don't know the seller 😀 )
I can't even begin to tell you how many issues (which were not apparent) I've fixed with it. 😀
It will show you ESR, VLoss, capacitance, everything you need to know to determine a cap's health (and many times, with just some exceptions, you can even test the cap while in-circuit)
Here's an example that I have from just this week.
The green capacitor is dead (the "well known" Chhsi bad brand), originally a 470uF/16V 😀, I removed it from a SS7 board that refused to POST, no matter how many times I tried. Notice that it doesn't appear to have any issues (no bulging, no leaking), in fact it looks pretty good.
The purple capacitor is a good 330uF/6.3V Sanyo cap, I removed it from a Socket 8 motherboard (VS440FX) that was in top shape, but I still wanted to give it the VIP treatment (since it's the only Socket 8 board I have), and replaced all its capacitors with new Panasonic FM caps.
The pics are probably self-explanatory (look at the ESR/Vloss/capacitance values on the green cap).
And, yes, the SS7 is alive and kicking after the recapping.
Bottom line, any retro enthusiast should have one of these. 😀
    617.48 KiB
    608.9 KiB
    827.42 KiB
    746.19 KiB
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 2 of 18, by Nexxen
bloodem wrote on 2021-08-14, 09:43:
Well, thanks for the explanation!!
This is pretty straightforward.
Astonishing how it can affect a healthy board.
Aaaaaaaaaaaand... it's bought.
I added a recap job to the to-do list.
I removed a couple of caps and the board POSTs 4/5 times without too much trouble.
Less is better I think 😀
Reply 3 of 18, by bloodem
Nexxen wrote on 2021-08-14, 10:21:
You're welcome. 😀
Well, depending on the circuit and on the health of those caps, I'm guessing that removing them could sometimes improve things. 😀
I would not use the board without those caps, though. Depending on their purpose, there's a chance that using the board like this might result in permanent damage of some other components (like ICs).
Reply 4 of 18, by Nexxen
bloodem wrote on 2021-08-14, 12:15:
You're welcome. :-) […]
You're welcome. 😀
Not using it until recapped.
I'm already happy enough with it working again.
Unbearably hot summer days yield something finally!
Personally I can't see why such old boards can't get free schematics for repairs.
The retro community is there and kicking and it's not going to push down $$$ figures 😀
Reply 5 of 18, by AlexZ
These testers are a good idea. I'm gonna get one myself. It seems using old boards with original caps is a disaster waiting to happen.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, NVIDIA GeForce FX 5600 128MB, Voodoo 2 12MB, 80GB HDD, Yamaha SM718 ISA, 19" AOC 9GlrA
Athlon 64 3400+, MSI K8T Neo V, 1GB RAM, NVIDIA GeForce 7600GT 512MB, 250GB HDD, Sound Blaster Audigy 2 ZS
Reply 6 of 18, by Ydee
Which one of these do You have? The fake (FEJK) clone allegedly has altered PCBs, a smaller battery and a high failure rate.
Reply 7 of 18, by bloodem
Ydee wrote on 2021-08-15, 09:54:
I didn't even know there were two versions. 😀
Anyway, yeah, I just checked right now and I have the fake/clone, with a 350mAh battery (I actually have two). I bought them 1.5 years ago and so far they've been great, had no issues with them.
Although, yeah, now that I think about it, the battery could last a bit longer. However, this has never been an issue for me... I'm not using them professionally anyway. 😀
Reply 8 of 18, by Nexxen
BTW, which is the best among the models?
I'm going to check and see what I'll get.
Reply 9 of 18, by Ydee
I really don't know about the versions and how many clones there are. I just want to buy some and I came across this link: http://www.hezkyden.cz/archiv/tc1-a-cinske-padelky/
That's why I wanted to know what version he had when he was happy with it and it worked.
Reply 10 of 18, by cyclone3d
Does the mfg of the originals have an eBay store?
There are a ton of different listings and would like to make sure I get an original.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 11 of 18, by bloodem
cyclone3d wrote on 2021-08-15, 15:12:
I really don't know, but I wouldn't worry too much. I have the "fake" ones and they've really been great. 😀
I paid $30 for two, and have had them for a year and a half. If they last for 3 - 4 years it's all good, I got my money's worth. 😁
Reply 12 of 18, by AlexZ
There seem to be multiple models - TC1, T7, T7-H. T7-H seems to be upgraded T7 with bigger display. TC1 is cheapest and should be enough.
There is also T4 model which works with regular 9V battery and comes without a plastic box. However it is possible to buy a transparent box for it. Another option is GM328A.
Reply 13 of 18, by Ydee
The original was designed and created (according to web sources) in Germany, The Chinese just "initially" took over and started production. On Ebay, Ali and elsewhere are then quality and lower quality clones. Probably the cheapest will be the most simplified, but a higher price does not automatically mean higher quality. They're identical on the outside.
We have a two-year guarantee here in the Czech Republic, so I'm not that worried about buying a clone or an "original". But of course I don't want to bother with RMA.
bloodem wrote on 2021-08-15, 15:49:
Here they are with two-year warranty prices from $20 to $35, which is ok price. Thanks for answer!
AlexZ wrote on 2021-08-15, 17:35:
Yes, I know, everything built on ATmega.
Reply 14 of 18, by Nexxen
Tested 2 caps, 6.3V 1500µF:
≃1620µF with 1.3 and 1.6% V-loss
Rubycon
Doesn't look bad for 20+ yrs electrolytic caps.
Reply 15 of 18, by bloodem
Well... if they're Rubycon, then that says it all. 😀
How's the ESR?
Reply 16 of 18, by Nexxen
bloodem wrote on 2021-08-17, 05:48:
How's the ESR?
Shoot, I forgot to write it!
0.09 ohm and 0.06.
Reply 17 of 18, by Nexxen
Probably I can leave all Rubycon a Nichicon and desolder all the others before starting with the more reliable brands.
20+ years and still doing well, kudoz!
I have to find a way to buy at stock prices in the EU, always wait from China makes every repair a months long job.
Reply 18 of 18, by Nexxen
I got new caps and decided to desolder some and test them.
All Rubycon were still above spec, max 2% Vloss and 0.12 to 0.18 ohm.
And they are 20+ years old...
A few non Rubycon were 10% lower than rated and I replaced them.
These non Rubycon were moving on one leg or the other. Bad soldering job. By replacing them the board starts up as expected, no delays, no nothing.
Someone replaced them and I didn't check thoroughly.
My misery!!
