First post, by DosFreak
Was checking out:
https://github.com/apuder/TRS-IO
Which enables online connectivity for the Trash 80
and noticed the following which allows access to newer versions of SMB and that it can be compiled for Windows
https://github.com/sahlberg/libsmb2
There's also:
https://github.com/sahlberg/libnfs
https://github.com/sahlberg/libiscsi
Likely is incompatible with older versions of VS and I don't see anything about Mingw-64 but could be a start.
Spent this morning trying to figure out why 9x and NT4 couldn't talk to my TrueNAS which they haven't been able to for a couple of months. Looks like an update unchecked NetBIOS. Re-enabled that and all is well again. Before that had to rely on WinSCP which worked well enough but not as convenient.
Make your games work offline
