First post, by renejr902
Hi! I'm back, long time no see. I bought a 386sx motherboard from Microcomputer system, cant find info or jumper, not on stason or vogons wiki. Thanks. Its like l'm the first one to have it for years.
Thanks a lot for Help.
See pictures :
https://imgshare.io/image/peOcgc
https://imgshare.io/image/peOeQY
https://imgshare.io/image/peOHRZ
https://imgshare.io/image/peOqEy
https://imgshare.io/image/peOJv4
https://imgshare.io/image/peOTq6
https://imgshare.io/image/peOuCn
https://imgshare.io/image/peOQNO
https://imgshare.io/image/peOGsF
https://imgshare.io/image/peOKe9
https://imgshare.io/image/peOoEQ
Edit: it works great.
https://ibb.co/7SmsTdg
Do you see any cache memory ?
Maybe these empty socket can have some ?
Im surprised 1.84 processor benchmark is very low, maybe because it has a math coprocessor and its confuse this utility if im remembrer correctly ?
I tried Keen 4, it runs ok, a few hiccup during gameplay, but im surprised menu loading is so slow. My 386dx33 runs menu flawessly.
Edit 2: Moon Patrol is still too fast 🤣! It still froze in beginner level. But works in Champion difficulty.
I wont buy a 8088 soon, but do you think a 286 at 8mhz, 10mhz or 12mhz can help for this game ?
( i can runs it better with my p2 233mhz with disable cache, my only pc that runs like a 286 with disable cache.)
https://ibb.co/Wg0FVvd
Reply 1 of 11, by Deksor
The 386SX is just a slow CPU, especially at 16mhz, it's a bit slower than a 16mhz 286 (but more capable with its instruction set). There is no cache on this board. Cache wasn't common on 386SX platform, it was mostly a DX thing.
Can you please take a clean picture with all the expansion slots empty so we can add it to uh19 ?
Taking a photo of the POST screen would be helpful as well for identification (dumping the bios would be even more useful, I can give you the program you need for that)
Reply 2 of 11, by BitWrangler
renejr902 wrote on 2021-08-20, 08:23:
Edit 2: Moon Patrol is still too fast LOL! It still froze in beginner level. But works in Champion difficulty. I wont buy a 8088 […]
You could try one of the classic slowdown utils on that, like the AT_Slow utils here... http://www.ittnnet.com/downloads/AT/at.html
Reply 3 of 11, by renejr902
Deksor wrote on 2021-08-20, 12:08:
I will do it in a few days. I will remember it. Its not the first time you asked me this, i did it for other motherboard in the past.
Reply 4 of 11, by renejr902
BitWrangler wrote on 2021-08-20, 15:35:
Thanks a lot, i tried several slowdown program, but this one im not sure, i just read the .doc. I will try it very soon. thanks again
Reply 5 of 11, by BitWrangler
A lot of them that are popular on here are for slowing 486 or pentium machines so might be too slow with a 386sx16, so I thought those ones would be more the right ballpark.
Reply 7 of 11, by renejr902
BitWrangler wrote on 2021-08-20, 20:05:
The utilitie work great , i found a newer version at 4.10. In this new version you can select mhz for the cpu instead. It works really good for most 8088 games, i tried a lot of them. But Moon Patrol still froze at any parameter. All others games works very good, better than ever. Thanks again.
Reply 8 of 11, by renejr902
Deksor wrote on 2021-08-20, 21:33:
Thanks 😀
There's probably a turbo header on your motherboard too
Thanks a lot for this information, i found the turbo header by myself. I checked with Landmark LM20 and Sysinfo6 and i got 4.5 on sysinfo6, exactly like a 286 8mhz at cpu. It seems that turbo cut the mhz speed by half, thats great and help with several older 8088 games. I wont forget it, i will post my motherboard information soon.
Thanks again.
Reply 9 of 11, by renejr902
Hi! I had some free time. I took the pictures you need ( PC booting with bios info and motherboards without isa cards and cable ) see below
I could not dump the bios, uniflash was not working, it says no pci bus.
Hope you enjoy and can add it to the database.
( If you find a way to dump the bios i will make it later in a few days, i have to work a lot in the next days)
Edit: ( If you find some info about the motherboard jumpers and switch or bios update, let me know thanks )
https://imgshare.io/image/pe0lK6
https://imgshare.io/image/pe0nwc
https://imgshare.io/image/pe0OOe
https://imgshare.io/image/pe0aWy
Reply 10 of 11, by renejr902
( check my last post before this one i posted 4 others pictures)
Edit2: Some more pictures and ebay url of that motherboard auction where i bought it:
https://imgshare.io/image/pe0704
https://imgshare.io/image/pe0IaO
https://imgshare.io/image/pe0dUF
https://imgshare.io/image/pe0EMn
https://imgshare.io/image/pe0MfY
https://imgshare.io/image/pe0iF9
https://imgshare.io/image/pe0sKP
https://imgshare.io/image/pe0XWQ
https://imgshare.io/image/pe0A25
https://imgshare.io/image/pe09MH
https://imgshare.io/image/pe0PIu
https://imgshare.io/image/pe0WHX
https://imgshare.io/image/pe0xFf
https://imgshare.io/image/pe0jzp
https://imgshare.io/image/pe0mYd
https://www.ebay.ca/itm/133289876058?ssPageNa … 353.m2749.l2649
Edit2:
4 other clean pictures of cpu, fpu and chipset
https://ibb.co/F7MPT5K
https://ibb.co/ZSz9drV
https://ibb.co/fvbBRpL
https://ibb.co/Fxdhpqj
