First post, by squelch41
Hi,
Was in need of a project so got a ms 6119 motherboard. Have updated the bios to the newest version (slightly unnerving as wasnt 100% sure of model but all's well that ends well!).
Mine is not natively coppermine compatible - it's the older revsion.
My question is, using a slocket adapter, should celerons/p3s be ok as long as 100mhz fsb and voltage ~1.7v or above (pretty sure the board will just provide 2v)?
Some slockets have voltage jumpers - are these just to instruct the motherboard or do they have regulators on them? - most seem to have 1.8v as the lowest voltage
Also, it looks like most need a minor mod to use the ~1ghz celerons and p3 - is that generally the case?
Want to just see how far I can push the board!
Thanks
V4P895P3 VLB Motherboard AMD 486 133MHz.64mb RAM, CF 4Gb HDD,
440bx MSI 6119, modified slocket , Tualitin Celeron 1.2Ghz 256mb SD-RAM, CF 4GB HDD, FX5200 gfx
386sx 20MHz ICL NB386s laptop, 4mb RAM, modified bios with XT-IDE, CF 512mb, 387 FPU
