First post, by SteveC
Hi all,
As mentioned in the 'Bought these (retro) hardware today' thread I got a Toshiba T2130CS laptop off eBay recently where the seller said the screen was faulty. Turns out it wasn't and the machine worked fine for about 20 mins or so then started crashing a lot, so much so that it often failed to boot.
The attachment 20210823_215150.jpg is no longer available
I noticed I could run the laptop if I sat it in front of my air con unit so thought heat could be to blame. So I stripped it down hoping to see a heatsink what needed new paste or something but it doesn't have a traditional heatsink or paste inside - it had this pink and black thermal pad instead.
The attachment toshiba 486 cpu thermal pad.PNG is no longer available
In the end it looks like something had possibly been spilt (or even a bug died?) and somehow corroded a few of the CPU pins.
The attachment toshiba 486 cpu.PNG is no longer available
The attachment WIN_20210823_13_05_45_Pro.jpg is no longer available
I cleaned it all up and it's been working absolutely perfectly since!
After a few charges/discharges even the battery seems to be working! Currently up to 50 mins running 😀
A video of my endeavours is here https://www.youtube.com/watch?v=EKSRXGYhNp8 (HD will come along when YouTube finishes processing)
Cheers,
Steve
Reply 1 of 1, by Horun
Nice ! I like the early Toshiba's !
