First post, by shimart
I'd like to make a MICRO 8088.
But it's almost impossible to get FARADAY FE2010A.
I searched and found that there is a clone model PROTON PT8010AF.
Will PT8010A work even if I put PT8010A in FE2010A seat?
The attachment Cap 2021-08-25 13-37-43-307.jpg is no longer available
The attachment Faraday_Technology-FE2010A-image.jpg is no longer available
Reply 1 of 13, by Thermalwrong
Hey I've been wondering the same thing, although some youtube videos about an NEC V40 recently drew my interest away.
Couldn't ever find a datasheet for the PT8010AF chip but from what I've read they are interchangeable.
If you had the PT8010AF, you could check whether the grounds match. Or if you ever happen to come across this board, you could trace out where the pins go and see if they match up with where the FE2010 pins go. The bidding went too high for me to bother with this one but the pictures might be useful for reference:
The attachment pt8010af-6.jpg is no longer available
The attachment Proton.jpg is no longer available
As an alternative, check these out, he hasn't released the schematic but the NEC V40 integrates much of the functionality needed for an XT for just some other basic logic chips to be needed for a working XT: https://www.youtube.com/watch?v=LQeBS97YZlU
https://www.youtube.com/watch?v=UY2iFsZFy_A
I'm really tempted to get one, but the keyboard controller is tough to find
Reply 2 of 13, by shimart
Thank you for your useful information.
I'll have to zoom in and look at the picture slowly. 🤣
I asked PT8010AF vendors for datasheet, but they say they don't.
The insidious replicas and everything seems to be a secret.
Reply 3 of 13, by waterbeesje
Just a guess. The secret may well be that it's a copy of a copyrighted chip that Proton doesn't have a licence for. If I did this, I wouldn't be happy to release any more info than saying "it's 100% compatible" either 😜
Stuck at 10MHz...
Reply 4 of 13, by sander
shimart wrote on 2021-08-25, 04:45:
I'd like to make a MICRO 8088. But it's almost impossible to get FARADAY FE2010A. I searched and found that there is a clone mod […]
Pinout looks the same (there is a match on VDD & VSS). But it doesn't seem to be a direct replacement in my setup. It might need different bios code, more investigation is needed..
[edit]
Meanwhile I've matched the following pins with the FE2010(A):
VDD
VSS
AD0
AD1
AD2
AD3
AD4
AD5
AD6
AD7
A8
A9
A10
A11
A12
A13
A14
A15
A16
A17
A18
A19
IOR
IOW
AEN
RST
READY
CPUCLK
INTR
S0
S1
S2
ESPI
IRQ4
IRQ6
IRQ7
not 100% sure as pinout of connecting chips are unknown:
KBCLK
KBDATA
IRQ2
IRQ3
IRQ5
[/edit]
Reply 5 of 13, by spark2k06
sander wrote on 2021-09-01, 09:53:
Meanwhile I've matched the following pins with the FE2010(A): VDD VSS AD0 - AD7 A8 - A19 IOR IOW AEN RST […]
VDD
VSS
AD0 - AD7
A8 - A19
IOR
IOW
AEN
RST
How did you do it? from photographs provided by Thermalwrong?
Can you share your progress on this? 😀
https://www.tindie.com/stores/spark2k06/
https://hackaday.io/spark2k06
Reply 6 of 13, by sander
spark2k06 wrote on 2021-09-03, 04:36:
I actually have a working 8088 laptop with Proton chipset (see attachment). I wish I had the motherboard shown by Thermalwrong, that would make reversing a whole lot easier. As it's not a direct replacement in my setup (commodore PC-I motherboard with FE2010) I wanted to be sure my aliexpress proton chip is working so I replaced the laptop proton with the aliexpress one, proton chip is definitely working and is not a counterfeit. Reversing was done by tracing known pins (8088, F82C710, etc..) back to the proton, that's how I verified the above. I hope to find the differences so we can all further enjoy Sergey's work..
[edit]I wish my machine had a normal ISA bus, then I would have been done[/edit]
The attachment IMG_20210904_101451.jpg is no longer available
Reply 7 of 13, by spark2k06
sander wrote on 2021-09-04, 08:25:
I actually have a working 8088 laptop with Proton chipset (see attachment). I wish I had the motherboard shown by Thermalwrong, […]
Great!
I have found more photographs with high detail in the following blog:
http://www.dosdays.co.uk/topics/xt_restoration_pt1.php
Reply 10 of 13, by Thermalwrong
Woo, quite happy to see I was right on my guess 😀 Time to buy some and make an 8088 SBC
Reply 11 of 13, by ayandon
@shimart , have you tried PT8010A?
I want to restore my late father's 1st ever computer IBM ET&T PC-XT that he gifted me.
Hope you will be kind enough to guide and support me to restore his loving memory.
Reply 12 of 13, by shimart
ayandon wrote on 2023-03-15, 17:39:
I made Micro8088 & Nao8088 on PT8010a.
It's Good worked. 👍
Reply 13 of 13, by ayandon
shimart wrote on 2023-03-16, 17:15:
It's Good worked. 👍
Thanks for sharing.
Pls do share some pics of your setup.
