First post, by Kahenraz
I used the wrong retention arm with a particular cooler that had a larger gap between the base and the clip. It only took a few minutes before I heard a loud *PLING!*.
I had put all of my retention clips into a bag without realizing that there is no standard clip and that one may not fit on another heatsink.
The correct clip for this heatsink latches not only on the primary hook but also the larger, bulker one next to it to distribute some of the force. This is the only time I've encountered a clip that uses this.
Thankfully, the board that was damaged is my least favorite and would be useful as an attempt at repairing this kind of damage.
Does anyone know how difficult it is to replace this socket and whether it's possible to do so reliably? I don't know if there are traces deeper inside the PCB that might not make contact if only the outermost pad is soldered.
The attachment IMG_20210811_200330.jpg is no longer available
The attachment IMG_20210825_210943_resize_22.jpg is no longer available
Reply 1 of 31, by cyclone3d
Does it not hold the heatsink properly with the correct clip with the middle tab. Broken off on the socket?
It is going to be a huge pain to replace the socket itself.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 31, by Intel486dx33
Can you clean up that broken plastic clip with a utility knife ( razor blade )
And then glue on a piece of plastic using J.B. weld ?
Reply 3 of 31, by Kahenraz
cyclone3d wrote on 2021-08-26, 01:30:
When using the correct clip, the heatsink tilts to the side due to uneven tension. Also, yes. I don't think I could even source a replacement socket if I wanted to. And it might not be possible to remove an existing socket from a dead motherboard or slocket without destroying it in the process.
Intel486dx33 wrote on 2021-08-26, 01:47:
I have had J.B. Weld fail on more perfect surface applications. I would not trust epoxy to hold the force of a retention clamp on such a small surface area. It might work. It might also fail and crash into something and start a fire.
Reply 4 of 31, by cyclone3d
JB Weld will definitely not hold. QuickSteel might hold but I probably wouldn't trust it on that small of a piece either.
Some of the older coolers used a bracket that used the socket clips caty-cornered from each other. That way the one side would try to angle the cooler one way and the clip on the other side would try to angle it the other way and you would end up with a cooler that was sitting flat.
YMF7x4 Guide
Reply 5 of 31, by Kahenraz
cyclone3d wrote on 2021-08-26, 02:22:
I've never seen one of these before. Can you find a photo?
Reply 6 of 31, by cyclone3d
Kahenraz wrote on 2021-08-26, 02:26:
Pretty sure I have one. Will be a few days before I can pull it out and take pics.
YMF7x4 Guide
Reply 7 of 31, by AlexZ
One option would be to find a place very close to the socket with no PCB traces and drill a hole through it using a pillar drill. I would say right where the hook was previously. You would need a custom retention arm and screw it to the board.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, GeForce FX 5600 128MB, Voodoo 2 12MB, Yamaha SM718 ISA
Athlon 64 3400+, Gigabyte GA-K8NE, 2GB RAM, GeForce GTX 260 896MB, Sound Blaster Audigy 2 ZS
Phenom II X6 1100, Asus 990FX, 32GB RAM, GeForce GTX 980 Ti
Reply 8 of 31, by Joakim
Happened to me and I just glued it with some cyanoacrylate glue. It works on plastics just takes a lot longer to set. Oh an if you want to speed up the process try pouring baby powder on it, but I wouldn't do it in this case. I fixed my wife glasses a few times with it..
Reply 9 of 31, by BitWrangler
In this particular case there's a nice area of clear board right ahead of it... make a metal hook with a pad that sits on that clear area, glue it down with regular epoxy, after sanding coating off board.
Reply 10 of 31, by drosse1meyer
What are you running in this system? Could you get by without a clip using paste+heatsink or something and a lighter retention mechanism?
Reply 11 of 31, by Doornkaat
Why not just replace the socket?
Reply 12 of 31, by BitWrangler
drosse1meyer wrote on 2021-08-26, 17:17:
By the size of the heatsink something at 124x6 on 2.8v at least 🤣 ... unless it's a tillamook at 40o or an M2 at 300
Reply 13 of 31, by luckybob
Doornkaat wrote on 2021-08-26, 17:53:
This is the correct answer.
here is me replacing a socket-370..... socket. https://www.youtube.com/watch?v=BZ7Moxa2JhI
It's rather easy, if you have a desoldering pump/station and a replacement socket.
Reply 14 of 31, by BitWrangler
They seem easier to find than I thought, https://www.peconnectors.com/sockets-pga-cpu- … emory/hws11107/
Reply 15 of 31, by Kahenraz
I wasn't able to find any replacement sockets when I had searched earlier; thank you. I'll probably go ahead with this to build some experience in the event I would ever need to do this on something important.
This motherboard is very unloved as it is Compaq OEM and has an extremely annoying COMPAQ logo that displays at boot that lasts foreeeever! And whether it will actually boot into the BIOS is pretty hit-or-miss and seems to only work maybe 50% of the time.
Reply 16 of 31, by Grem Five
If you dont want to replace your socket 1st I would try modifying your heatsink.
All you need to do is drill and tap a hole right above the left ear of your retaining clip and mount a screw so it holds it without the clip tilting when its also clamped on that larger clip on the right side. I have made this modification and it holds the heatsink quite flat.
My heatsink has dual springs but it works the same way as a single spring would by not allowing the 3 holed bracket to tilt and applying even pressure. The one pictured has a small T-nut I machined that the screw is fastened into but would also work on a single spring type if you just tap right into the alum at the proper height. The motherboard I did this too is a Tyan S2080 Tomcat that I got dirt cheap because the ear on the socket was broken... its running a 1.4 gig Tual P3 nice and cool. I checked to make sure it was sitting flat by checking it had even thickness paste distribution... I wanted to use some pressure paper to check how well its seated but that stuff is too damn expensive.
This fix works best if the broken ear is on the side of the socket that you fasten the retaining clip down to 1st as if its the other side it can be more problematic as you would have to go over the screw as you are trying to fasten it down or put the screw in after you try to clip it while trying to push down the corner of the clip.
(edit) in my pic you cant see it but the little t-nut I made is putting pressure on the spring and holding it and the clip in the proper orientation but if you drilled and tapped or just drilled and used a self tapping screw you would need the dia of the head of the screw to hold the edge of the clip at the proper orientation. Proper measurement in where to place the screw hole would be more important then my setup as I can adjust mine up and down in the slot clearance that the spring uses.
Reply 17 of 31, by bearking
Grem Five wrote on 2021-08-27, 23:51:
If you dont want to replace your socket 1st I would try modifying your heatsink. […]
Hey, that's a really elegant workaround!
Great idea! Thanks for sharing!
Reply 18 of 31, by the_patchelor
some days ago I got a broken S.370 on a Abit board.... fixed it with a desoldering pump/station. So I removed it first from a other cheapo board, removed it from Abit and soldered it back.... many many solder points 😉
The attachment IMG_7425.jpg is no longer available
Reply 19 of 31, by BLockOUT
the_patchelor wrote on 2021-08-29, 12:42:
tried to do that many times with a desoldering gun on a socket 370
and some of the metal pins broke, funny thing is that i was not even moving them in circular motion.
too many, and when i was removing about half of them a pin broke. happened twice
regarding the original topic, that cooler is not for socket7, they are for 462.
Socket7 coolers do not need that amount of pressure, you can get an original socket7 coolersand you will notice that the force in the clips is very light.
on socket 462 in the other hand, the coolers need a really big ammount of force, because of the amount of heat that they can produce
