First post, by Doppler
Hi guys!
I found a partially working motherboard which has missing element on it. Probably a voltage regulator. I'll be very happy to know what it is 😁
I attached a photo explaining which part is it.
The attachment 20210523_192458.jpg is no longer available
Reply 1 of 6, by Horun
Yes that is a Voltage regulator. Need someone who has that board to give you the exact part number.
Reply 2 of 6, by TheMobRules
I have the Gateway OEM version of that board. The part number of the regulator is LT1584CT.
Reply 3 of 6, by Doppler
Thank You Very Much! Time to repair it! 😀
But i got another question - does the LT1584CT have any other signs on the case? when I search it in the producers datasheet I see lots of different versions of this regulator under the same model number.
Please TheMobRules, can You give me exact model number, or every letter printed on the case of this element?
Thanks!
Reply 4 of 6, by TheMobRules
What you want is the plain LT1584CT, which is the adjustable version of the regulator. The other variants with suffixes such as -3.3, -3.38, -3.45 or -3.6 output a fixed voltage, but none of those will work here since it is probably used to generate the necessary 2.8V for MMX processors. Here's a link to the adjustable version on Digi-Key:
https://www.digikey.com/en/products/detail/an … 84CT-PBF/890729
Reply 5 of 6, by Doppler
I owe You 😀
It's a bit expensive. Wonder if it was torn appart by accident 😉
Reply 6 of 6, by Doppler
Nope. Cant get any of these in my country 🙁 importing would be too expensive. Any chance for LT1584CT equivalent? Could anyone search your boards to look for 2,8V regulator?
