First post, by Odiseo
Some of you may remember the topic I opened regarding my Chaintech Socket 7 motherboard in June. Long story short, I couldn't get it to work anymore.
I got another Socket 7 system a while ago.
Motherboard brand: Vtech
Motherboard model: MB520ND 35-8266-01
Chipset: VX
Here are links to some pages with information: link 1|link 2|link 3|full manual
After I installed Windows 98SE, the system crashed a few times. I suspected the cause was faulty RAM, so I tested the SDRAM modules (one 32MB, one 16MB) separately under Memtest86. Both modules turned out to be broken, so I bought three 32MB SDRAM modules. After receiving them a few days ago, I let Memtest86 run 8 passes on each of them. Not a single error was found. The system now has 64MB of RAM.
As was the case with other Socket 7 motherboards that featured SDRAM slots (at least, in my understanding), mine has two of this type. I'm keeping 1 module as a spare.
I still have two issues with the system.
  • 80-wire ribbon cable: hard drive not detected
When I connected the hard drive to the motherboard through an 80-wire ribbon cable, the drive was not recognized. I connected the blue connector to the motherboard and the (black) end connector to the hard drive, the only drive on the cable. I tried three different 80-wire cables, all of which yielded the same result: the BIOS could not see the hard drive.
I am again using a 40-wire cable, with which I never have this issue. I would like to use an 80-wire cable because of the higher transfer speeds.
  • PCI USB card: no devices detected
When I bought the system, there was a VIA USB card installed on one of the PCI ports. I went to VIA's driver download page on my Windows 10 PC and downloaded the Windows 98SE drivers for both USB 1.1 and USB 2.0. The 1.1 version would not install. The 2.0 version seemed to install successfully; however, when I connected a device, the card did not detect it. I tried a flash drive, which lighted up for a few seconds, and a mouse. Luckily, I bought a serial mouse from the same guy who sold me this PC.
I considered the possibility that the updates for USB contained in Auto-Patcher might resolve the issue. There was no result after I had installed them.
I ended up inserting the USB card on the motherboard of my Pentium 3 system. It works fine in that system.
Additional questions
  • Motherboard USB Connector
As is visible on the schematics in attachment, there is a USB connector on the motherboard. It has 6 rows of two pins each. Is this what a USB 1.1 connector looks like?
I took a look at the motherboard header on the USB 2.0 bracket in my Windows 10 PC. It has only 5 female connectors (sixth one is filled up), so it's not compatible with the male connector on my Socket 7 motherboard.
  • Updates
I let Auto-Patcher install most of its updates and hotfixes, including those in both the "Dec. 2007 final" version and the "Dec. 2008 Upgrade".
Which other updates and hotfixes for Windows 98SE can you recommend me?
Reply 1 of 6, by canthearu
Just a couple of notes:
* 80 Wire connector for IDE drives is only needed on Ultra DMA-66 and higher modes. Your motherboard does not support Ultra-DMA, so you should not be using the 80-wire cables.
* USB PCI card: VIA cards are not very good on this system, there are technical reasons why it doesn't work, which I can't be bothered looking up right now. Use a NEC based USB 2.0 card instead, they will probably work better.
* For the onboard usb ports, the manual is here: http://www.win3x.org/uh19/motherboard/show/5687. You will need to wire each wire individually as it doesn't look like a standard USB header layout.
* I normally don't run any updates on Windows 98. The unofficial service packs and stuff tend to cause as many problems as they supposedly solve.
Reply 2 of 6, by Anders-
null
Måttfull och balanserad.
Reply 3 of 6, by Gmlb256
Odiseo wrote on 2021-08-29, 20:57:
These USB connectors found on non-Super Socket 7 motherboards are not 2.0 and sometimes even poorly documented. On one motherboard that connector is more similar to the ones found on modern motherboards but on other ones it could have the one of the rows inverted or has an entirely different pinout instead.
canthearu wrote on 2021-08-29, 21:41:
There's one legitimate update CD on VOGONS drivers for Windows 98. It doesn't have all the latest fixes but I don't think it will be necessary for retro builds though.
I stay away from unofficial updates when possible as they tend to contain "tweaks" and hacks that can mess up the system on the long run.
Reply 4 of 6, by Odiseo
Thanks for the suggestion with regard to NEC-based cards!
Gmlb256 wrote on 2021-08-29, 22:22:
Never saw this before. Looks very interesting. Will definitely check this out on both of my classic PC's (one Socket 7, one Pentium 3).
Reply 5 of 6, by dionb
Odiseo wrote on 2021-08-29, 22:36:
Word of warning (out of the technical details we didn't mention): the NEC chipset works fine with old PCI 2.1 5V-only slots, but not all cards those chips are stuck on do as well. Most will but you may be unlucky. I have two from Sweex (low-end bottom-feeding brand) that work just fine, and a much more fancy Promise card with the same NEC chipset that does too.
I fully second the previous comment on using plain vanilla images and adding the needed updates manually. That 'auto' stuff isn't bad, but it's the sort of software that might mess up and then you'd need at least the knowledge you would to do it manually.
As for the motherboard USB connector - there were no standards back in 1996. You need to find the pinout and either (unlikely) find a USB bracket+cable that matches, or use DuPont cables to convert to another one. To find the pinout, a multimeter is very useful. First set it to continuity testing (or failing that just plain resistance - Ohm - measurement). Then with the computer off, see which pins are connected to ground by measuring between each of the USB header pins in turn vs the middle pins on AT power connector or anywhere else you know is at ground level. Note the pin numbers that are GND. Then turn the computer on and set the multimeter to DC voltage measurement. Measure between one of the ground pins and each of the others in turn. When it shows 5VDC you have the Vcc pins. Note those pin numbers. These are the vital pins (get these wrong and the smoke comes out). You can afford to mess around with the data + and -. Usually you'd expect to have Vcc data +, data - and GND in a row. If there are two other pins between Vcc and GND it's a fair bet they are data + and -. Test and see if that works. If not, try them the other way round (data - and +).
Note that Win98 USB support isn't great and USB 1.1 is glacially slow in any event, so the only thing the onboard USB is really useful for is keyboard and mouse.
Reply 6 of 6, by Warlord
None. The only updates I recommend are Installer 2.0, TCPIP Stack 1.4 , DX7, and Only if you have applications that require it IE5.5sp2 Otherwise don't update IE.
All those service packs and autopatchers only make the computer slower, cause instability, bugs and crashes. They fix problems that you don't even have, and create problems you don't even have at the same time.
