First post, by dormcat
Hi all,
I got a system with Athlon "Thunderbird" 1200C on Asus A7V133-C last week and, after some painstaking troubleshooting (turned out the SDRAM was faulty), I started testing the system with CPU-Z Vintage Edition and TOPBENCH. The BIOS has the option of turning L1 and L2 caches on and off; turning off L1 cache would drop the speed significantly to be equivalent to 486SX-25
420.7 KiB
1.07 MiB
1.53 MiB
1.49 MiB
However, unlike my Pentium-MMX build, turning L2 cache on or off on this T-bird build has no effect, with the difference of benchmark scores less than 1%, either with or without L1 cache.
Could it be
1. Norma: turning L2 off has little effect on T-bird builds
2. Normal: turning L2 off does slow down the system but CPU-Z and TOPBENCH simply can't reflect this; try another benchmark software
3. Abnormal: there's something wrong with CPU and/or MB
I know that companies like PCChips had the illegitimate practice of making fake L2 chips on their 486-era MB but I don't think Asus would do so in the era of P3/T-bird.
Reply 1 of 5, by Falcosoft
dormcat wrote on 2021-08-30, 10:54:
Hi all, […]
Hi all,
Could it be
You can check if the problem is 2 or 3 by using synthetic memory benchmarks that use different data block sizes.
The Tbird has rather big L1 cache (64K+64K) and not so big L2 cache (256K). So you should look at the results at 128K and 256K. If L2 cache is enabled then 128K-256K results should be slower than the L1 results (up to 64K) and faster than main memory results (bigger than 256K). If L2 cache is disabled then 128K and 256K results should be roughly the same as main memory results.
You can use e.g. cachemem under DOS or Sisoft Sandra under Windows to test this.
cachemem.zip
39.44 KiB
32 downloads
1666Mhz Athlon Tbred cachemem results with enabled 256K L2 cache:
Cache size/Memory speed info tool 2.65MMX - (c) 1999-2001, LRMS - DJGPP compiled
CPUID support detected... 'AuthenticAMD' with FPU TSC MMX
Family=6 Model=8 Step=1 Type=0 Chipset (Vendor/Device ID(Rev)): VIA/0305(03)
CPU clock: 1666.7 MHz
Using 32MB physical memory block (alignment = 32)
Bandwidth - MMX linear access test... Read/Write/Copy (MB/s)
Block of 1KB: 14530.9 / 12714.2 / 17031.7
Block of 2KB: 13734.0 / 12100.2 / 17747.5
Block of 4KB: 14121.4 / 12077.9 / 18113.1
Block of 8KB: 14323.3 / 12022.0 / 18300.7
Block of 16KB: 14426.3 / 11994.4 / 18397.8
Block of 32KB: 14482.7 / 11980.6 / 17776.0
Block of 64KB: 14440.5 / 11880.6 / 4507.4
Block of 128KB: 4958.2 / 5047.2 / 4493.7
Block of 256KB: 4960.9 / 5050.8 / 489.8
Block of 512KB: 877.2 / 327.7 / 490.0
Block of 1024KB: 876.6 / 329.0 / 490.6
Block of 2048KB: 873.2 / 355.3 / 490.5
Block of 4096KB: 872.0 / 363.7 / 490.5
Block of 8192KB: 871.4 / 367.4 / 490.5
Block of 16384KB: 871.1 / 370.3 / 490.4
Block of 32768KB: 871.0 / 367.6
Latency - Memory walk tests... ("pointer chasing")
Null size: 4 cycles 1 cycles (overhead 66 cycles)
steps: 4 8 16 32 64 128 256 512 1k 2k 4k (bytes)
Block of 1KB: 4 4 4 4 4 4 4 4 - - - cycles
Block of 2KB: 4 4 4 4 4 4 4 4 4 - - cycles
Block of 4KB: 4 4 4 4 4 4 4 4 4 4 - cycles
Block of 8KB: 4 4 4 4 4 4 4 4 4 4 4 cycles
Block of 16KB: 4 4 4 4 4 4 4 4 4 4 4 cycles
Block of 32KB: 4 4 4 4 4 4 4 4 4 4 4 cycles
Block of 64KB: 4 4 4 4 4 4 4 4 4 4 4 cycles
Block of 128KB: 4 5 9 18 20 20 20 20 20 20 20 cycles
Block of 256KB: 4 5 9 18 20 20 20 20 20 20 20 cycles
Block of 512KB: 15 27 48 96 184 230 231 234 240 253 278 cycles
Block of 1024KB: 15 27 48 96 184 229 231 234 240 253 279 cycles
Block of 2048KB: 15 27 48 96 184 230 232 236 245 261 294 cycles
Block of 4096KB: 15 27 48 96 184 230 232 237 246 263 299 cycles
Block of 8192KB: 15 27 48 97 183 230 232 237 246 264 301 cycles
Block of 16384KB: 15 27 48 96 184 230 232 237 247 265 303 cycles
Block of 32768KB: 15 27 48 97 184 230 232 237 247 265 303 cycles
This system appears to have 2 cache levels (enabled).
L1 cache (64KB) speed (MB/s): Read=14482.7, Write=11980.6
L2 cache (256KB) speed (MB/s): Read=4958.2, Write=5047.2
Main memory speed (MB/s): Read=871.1, Write=370.3
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 2 of 5, by Standard Def Steve
It's probably not turning off the L2 at all, because you would notice a difference.
I've had at least one system in the past outright ignore the L2 cache toggle in the BIOS. It was all or nothing with that particular system (turning off L1 in the BIOS would disable L2 as well). With both caches disabled, you could actually see the XP welcome screen fade in, using around 12 different shades of blue. Normally, you don't even see that fade-in effect because it happens so quickly. Who knew XP had speed-sensitive visual effects?
Reply 3 of 5, by dormcat
Falcosoft wrote on 2021-08-30, 13:07:
Thanks a lot! Turned out the L2 could be disabled with L1 alone enabled, but L2 always got disabled when L1 was disabled, just like Standard Def Steve said:
Standard Def Steve wrote on 2021-08-31, 00:05:
I ran cachemem twice just to make sure I had either enabled or disabled L2 back and forth, with L1 disabled.
With L1 and L2 both enabled (I'll just list Latency tests):
Block of 128KB: 4 5 9 10 20 20 20 20 20 20 20 cycles
Block of 256KB: 4 5 9 10 20 20 20 20 20 20 20 cycles
Block of 512KB: 19 29 59 109 181 182 184 187 194 207 234 cycles
Block of 1024KB: 19 29 59 108 181 182 184 187 194 208 234 cycles
Block of 2048KB: 19 29 59 109 182 183 185 190 200 218 261 cycles
Block of 4096KB: 19 29 59 109 182 183 186 191 201 223 264 cycles
Block of 8192KB: 19 29 59 109 182 184 186 191 202 224 267 cycles
Block of 16384KB: 19 29 59 109 182 183 186 192 203 225 269 cycles
Block of 32768KB: 19 29 59 109 182 183 186 191 203 225 270 cycles
L1 cache (64KB) speed (MB/s): Read=11301.1, Write=9191.6
L2 cache (256KB) speed (MB/s): Read=3684.8, Write=3682.9
Main memory speed (MB/s): Read=964.2, Write=288.5
With L1 enabled and L2 disabled:
Block of 64KB: 5 4 4 4 5 5 4 4 4 4 4 cycles
Block of 128KB: 20 29 58 109 181 182 184 187 194 207 234 cycles
Block of 256KB: 19 29 59 109 181 183 184 187 194 207 234 cycles
Block of 512KB: 19 29 58 109 181 182 184 188 194 207 234 cycles
Block of 1024KB: 19 29 59 109 181 183 184 187 194 207 234 cycles
Block of 2048KB: 19 29 59 109 181 183 185 191 200 219 259 cycles
Block of 4096KB: 19 29 59 109 182 183 186 191 202 222 263 cycles
Block of 8192KB: 19 29 59 109 182 183 186 191 202 224 267 cycles
Block of 32768KB: 19 29 59 109 182 183 186 192 203 225 269 cycles
This system appears to have 1 cache levels (enabled).
L1 cache (64KB) speed (MB/s): Read=11300.9, Write=9191.5
Main memory speed (MB/s): Read=964.3, Write=286.1
With "L1 disabled and L2 enabled" (as shown in BIOS), but L2 was in fact disabled altogether:
Block of 1KB: 242 242 242 242 242 242 243 242 - - - cycles
Block of 2KB: 242 242 242 242 242 242 242 243 242 - - cycles
Block of 4KB: 242 242 242 242 242 242 243 242 242 242 - cycles
Block of 8KB: 242 242 242 242 242 243 242 242 242 242 242 cycles
Block of 16KB: 242 242 243 242 242 242 242 242 242 242 243 cycles
Block of 32KB: 242 242 243 242 242 243 245 248 255 268 296 cycles
Block of 64KB: 242 242 242 242 244 243 245 248 255 268 295 cycles
Block of 128KB: 242 242 242 242 242 243 245 248 255 268 295 cycles
Block of 256KB: 242 242 242 242 242 243 245 248 255 268 295 cycles
Block of 512KB: 242 242 242 242 242 243 245 248 255 270 295 cycles
Block of 1024KB: 242 242 243 243 243 245 245 249 256 269 296 cycles
Block of 2048KB: 242 242 243 244 245 246 249 251 259 272 299 cycles
Block of 4096KB: 242 242 243 243 245 248 249 251 259 273 302 cycles
Block of 8192KB: 242 243 242 243 245 247 249 252 260 273 301 cycles
Block of 16384KB: 242 242 242 243 245 246 249 252 260 274 302 cycles
Block of 32768KB: 242 243 242 244 245 247 249 252 260 274 302 cycles
This system appears to have 0 cache levels (enabled).
Main memory speed (MB/s): Read=37.6, Write=139.4
With L1 and L2 disabled:
Block of 4KB: 242 242 242 242 242 242 242 243 242 242 - cycles
Block of 16KB: 242 242 243 242 242 242 242 242 242 242 242 cycles
Block of 64KB: 242 242 242 242 242 245 245 248 255 268 295 cycles
Block of 128KB: 242 242 242 242 244 243 245 248 255 268 295 cycles
Block of 256KB: 242 242 242 242 242 245 245 248 255 268 295 cycles
Block of 512KB: 242 242 242 243 242 243 245 248 255 270 295 cycles
Block of 1024KB: 242 243 242 243 243 245 245 249 256 269 296 cycles
Block of 2048KB: 242 242 243 243 244 246 248 251 258 272 300 cycles
Block of 4096KB: 242 242 242 243 245 246 249 251 259 273 300 cycles
Block of 8192KB: 242 242 242 243 245 247 249 252 260 273 301 cycles
Block of 16384KB: 244 242 243 243 245 247 249 252 260 274 302 cycles
Block of 32768KB: 242 242 242 243 245 247 249 252 260 275 302 cycles
With L1 enabled and L2 disabled, the difference could only be visible when data block sizes fell within 128KB or 256KB.
For the record, the Pentium-MMX 233MHz build (16KB L1 on CPU, 512KB L2 on MB) has a very different pattern:
Both enabled:
Block of 1KB: 2 2 2 2 2 2 2 2 - - - cycles
Block of 2KB: 2 2 2 2 2 2 2 2 2 - - cycles
Block of 4KB: 2 2 2 2 2 2 2 2 2 2 - cycles
Block of 8KB: 2 2 2 2 2 2 2 2 2 2 2 cycles
Block of 16KB: 2 2 2 2 2 2 2 2 2 2 2 cycles
Block of 32KB: 4 7 12 17 17 17 17 17 17 17 17 cycles
Block of 64KB: 4 7 12 17 17 17 17 18 17 17 17 cycles
Block of 128KB: 4 7 12 17 17 17 17 17 17 17 17 cycles
Block of 256KB: 4 7 12 17 17 17 17 17 17 17 17 cycles
Block of 512KB: 4 7 12 17 17 17 17 17 17 17 17 cycles
Block of 1024KB: 6 10 19 32 32 34 34 37 42 53 53 cycles
Block of 2048KB: 6 10 19 32 32 33 34 37 42 53 53 cycles
Block of 4096KB: 6 10 19 33 32 33 34 37 42 52 52 cycles
Block of 8192KB: 6 10 19 32 32 33 34 37 42 52 53 cycles
Block of 16384KB: 6 10 19 32 32 33 34 37 42 53 53 cycles
L1 cache (16KB) speed (MB/s): Read=1289.4, Write=169.9
Main memory speed (MB/s): Read=160.0, Write=169.2
L1 only:
Block of 16KB: 2 2 2 3 3 2 2 2 2 2 2 cycles
Block of 32KB: 6 10 19 32 32 33 34 37 42 52 53 cycles
Block of 64KB: 6 10 19 32 32 33 34 37 42 53 53 cycles
Block of 128KB: 6 10 19 32 32 33 34 37 42 53 53 cycles
Block of 256KB: 6 10 19 32 32 33 34 37 42 53 52 cycles
Block of 512KB: 6 10 19 32 32 33 34 37 42 53 53 cycles
Block of 1024KB: 6 10 19 32 32 33 34 37 42 53 53 cycles
Block of 2048KB: 6 10 19 32 32 33 34 37 43 53 53 cycles
Block of 4096KB: 6 10 19 32 32 33 34 37 42 52 53 cycles
Block of 8192KB: 6 10 19 32 32 33 34 37 42 53 53 cycles
Block of 16384KB: 6 10 19 32 32 33 34 37 42 53 52 cycles
L2 only:
Block of 1KB: 22 22 22 22 22 22 22 22 - - - cycles
Block of 2KB: 22 22 22 22 22 22 22 22 22 - - cycles
Block of 4KB: 22 22 22 22 22 22 22 22 22 22 - cycles
Block of 8KB: 22 22 22 22 23 23 24 22 22 22 22 cycles
Block of 16KB: 22 22 22 22 22 22 23 22 22 22 22 cycles
Block of 32KB: 22 22 22 22 22 22 22 22 22 22 22 cycles
Block of 64KB: 22 22 22 22 22 22 22 22 22 22 22 cycles
Block of 128KB: 22 22 22 22 22 22 22 22 22 22 22 cycles
Block of 256KB: 22 22 22 22 22 22 22 22 22 22 22 cycles
Block of 512KB: 22 22 22 22 22 22 22 22 22 22 22 cycles
Block of 1024KB: 25 29 37 49 49 49 49 52 57 66 66 cycles
Block of 2048KB: 25 29 37 49 49 49 49 52 57 66 66 cycles
Block of 4096KB: 25 29 37 49 49 49 49 52 57 66 66 cycles
Block of 8192KB: 25 29 37 49 49 49 49 52 57 66 66 cycles
Block of 16384KB: 25 29 37 49 49 49 49 52 57 66 66 cycles
L1 cache (512KB) speed (MB/s): Read=78.3, Write=92.7
Main memory speed (MB/s): Read=51.3, Write=92.7
Both disabled:
Block of 1KB: 58 58 58 58 58 58 58 58 - - - cycles
Block of 2KB: 58 58 58 58 58 58 58 58 58 - - cycles
Block of 4KB: 58 58 58 58 58 59 60 60 64 69 - cycles
Block of 8KB: 58 58 60 58 58 59 60 60 64 69 69 cycles
Block of 16KB: 58 58 58 58 58 59 60 60 64 71 69 cycles
Block of 32KB: 58 58 58 58 58 59 60 60 64 69 69 cycles
Block of 64KB: 58 58 58 58 58 59 60 60 64 69 71 cycles
Block of 128KB: 58 58 58 58 58 59 60 60 64 69 69 cycles
Block of 256KB: 58 58 58 58 58 59 60 60 64 69 69 cycles
Block of 512KB: 58 58 58 58 58 59 60 60 64 69 69 cycles
Block of 1024KB: 58 58 58 58 58 59 60 60 64 69 69 cycles
Block of 2048KB: 58 58 58 58 58 61 60 60 64 69 69 cycles
Block of 4096KB: 58 58 58 58 58 59 62 60 64 69 69 cycles
Block of 8192KB: 61 58 58 58 58 59 60 60 64 69 69 cycles
Block of 16384KB: 58 58 58 58 58 59 60 60 64 71 69 cycles
Main memory speed (MB/s): Read=27.2, Write=52.0
Hmm, seemed that cachemem couldn't recognize the 512KB external Pipelined Burst SRAM cache on Asus TXP4 MB.
Sorry for the long text; thanks again!
Reply 4 of 5, by Falcosoft
Just as I said so. Compared to contemporary P4 the L2 cache was not so important to Athlon CPU's performance. That's why even the Duron with its anemic 64K L2 cache was more than competitive with P4 Celerons. That 64K+64K L1 cache is huge even compared to today's processor standards.
The biggest difference compared to your P1 MMX setup is that the Athlon Tbird has on-die L2 cache so the motherboard has nothing to do with it. Also that's why disabling L1 cache also disabled the whole cache hierarchy.
Cachemem has no specific cache level detection. It only infers the levels based on the measured bandwidth. You have not posted the bandwidth results but I assume that the relative difference between L2 bandwidth and main memory bandwidth was so small on your P1 MMX system that cachemem must have thought it is within margin of error.
Reply 5 of 5, by dormcat
Falcosoft wrote on 2021-08-31, 07:19:
Indeed, the difference was visible (-33% read bandwidth) yet much less than other read bandwidth differences (3-4 times).
CPUID support detected... 'GenuineIntel' with FPU TSC MMX
Family=5 Model=4 Step=3 Type=0 Chipset (Vendor/Device ID(Rev)): Intel/7100(01)
CPU clock: 233.9 MHz
Using 16MB physical memory block (alignment = 32)
Block of 1KB: 1234.5 / 175.0 / 337.9
Block of 2KB: 1265.3 / 172.0 / 340.0
Block of 4KB: 1281.3 / 170.5 / 340.0
Block of 8KB: 1289.4 / 169.9 / 339.2
Block of 16KB: 1230.3 / 169.6 / 332.6
Block of 32KB: 239.8 / 169.4 / 226.4
Block of 64KB: 239.8 / 169.3 / 226.3
Block of 128KB: 239.9 / 169.3 / 224.0
Block of 256KB: 239.9 / 169.3 / 226.4
Block of 512KB: 239.9 / 169.2 / 226.4
Block of 1024KB: 160.0 / 169.2 / 124.7
Block of 2048KB: 160.0 / 169.2 / 124.6
Block of 4096KB: 160.0 / 169.2 / 124.6
Block of 8192KB: 160.0 / 169.2 / 124.6
Block of 16384KB: 160.0 / 169.4
