First post, by Lord Cervos
Hi,
First time poster. I just bought a HP PB400 486 computer that mostly works. Documentation on this motherboard is almost non-existent. The guy I bought it from stripped out RAM and I'm having some difficulties figuring out what type of RAM I can put in this computer and how much. I also think I've located the CMOS battery that needs replacing. I'm alright with a soldering iron. Since I've never worked on a PC this old could someone verify that is indeed the battery I'm looking at.
I plan on upgrading the CPU and adding in both a GFX card, and Sound card.
Here's the only documentation I could find.
https://stason.org/TULARC/pc/motherboards/P/P … -PB400-4MB.html
Here's the RAM slots (if that helps).
And the suspected battery.
Any other helpful comments are welcomed. Thanks.
