First post, by Robin4
I set up a 850MB hard drive on a 386 40 mhz motherboard. (the motherboard is a Contaq 386 / 486 one a puchased some years ago.
I can setup the hard drive in the bios with the following geometry:
Size: 849 Cyls: 1646 Head: 16 Precomp: 65535 Lzone: 1645 Sector: 63 Mode: Normal (there is no way to set it up on Large or LBA because 386 motherboards dont have them. So this is what i used.
I thought maybe it could used the full size of the disk. ( i know of the 504MB limitation) But it couldnt.
Do i need a later version of FDISK to do so??
Have installed ms-dos version 6.22 on it.. But there is also no way to make a extended partition for the remainder 300MB which should be usable.
Dont want to install a overlay software.
If there is no other way please tell me..
Reply 1 of 4, by BitWrangler
Strangely enough, limitation means limitation, you're gonna need something like "anydrive" to use all of it.
Edit: Though you can also stick an XT-IDE BIOS in the ROM socket of a Network card or one of those Mini ROM cards wiretap designed.
Reply 2 of 4, by pentiumspeed
That will work, as 500MB, that's the max on 386, and it will boot still.
Cheers,
Great Northern aka Canada.
Reply 3 of 4, by Robin4
Ok so my only option is to use an LBA controller card like the Promise IDE max?
Reply 4 of 4, by darry
Robin4 wrote on 2021-09-05, 01:54:
XTIDE is another option : https://www.xtideuniversalbios.org/ and https://bitbyted.wordpress.com/2016/05/03/xtide-on-a-lan/
or you could use DDO (dynamic drive overlay) software : https://en.wikipedia.org/wiki/Dynamic_drive_overlay
