First post, by kikendo
I have a 5.25" drive that started yesterday not closing and getting ruined.
Basically what happens is the metal axle that is connected to the latch, then stuck inside a plastic bit inside, rotates freely when the plastic inside needs to do "strength" to push the drive plate down.
I hope you understand what I mean. Basically the plastic bit inside and the axle have gone to a place here the inside metal axle will spin instead of staying stuck and making the inner plastic do its work.
A pic for reference:
file.php?mode=view&id=118495
Is there any way to fix this without needing a new part? At this point I might as well try to get a new drive if I can't fix this.
Reply 1 of 5, by BitWrangler
I'd just glue the cam piece back in position.
Reply 2 of 5, by Horun
yep ! Check the plastic cam as one of mine did that and was a white nylon type and not ABS or PVC type. Took a few different glues to find one that worked but it did. Also fixed one years ago using a micro drill thru the plastic into the metal shaft a bit and tapped a cut off micro brass screw into it, it still works too.
Reply 3 of 5, by kikendo
Great suggestions, thanks guys!
Any suggested glue? I just worry about metal/plastic contact, don't think Superglue would work.
How about plastic gun glue?
Reply 4 of 5, by cyclone3d
Quicksteel should work.
There are also a bunch of different types
Of multi-surface epoxies that should work
Just fine as well.
For any type of glue to hold adequately,
You will need to roughen up the surface to be glued
With sandpaper and then clean really well.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 5, by BitWrangler
Yah, I'd go with an epoxy type.
kikendo wrote on 2021-09-24, 15:13:
Not the generic craft type low temperature stuff. But if I found that all I had was the industrial high temp gun and multipurpose yellowy/beige glue, then I'd slide the cam as far up the shaft as it went, apply a coating round the shaft where it goes, then hold a soldering iron on it the opposite side to keep it nice and runny, then slide the cam into position and let it set up. .... and I'd only be about 60% confident that that wouldn't just make a mess you had to clean up/off before you got some epoxy because it didn't work.
