First post, by appiah4
- l33t++
I just revived a 286 board so I am now tinkering around with a platform I never owned before (Went straight from Amiga to 486). The board has 1MB RAM in two banks, and only finds 640KB of RAM at POST check (I assume the missing 384KB is in the UMB and therefore not shown as Extended?). Fine. My question is, what are my memory management options with a 286 with 1MB RAM? I'm assuming it's not worth going any further than MS-DOS 5.0 as far as versions go? So Aside from DOS=HIGH,UMB in CONFIG.SYS what options do I have? Can I call HIMEM.SYS aon this system to load programs into upper memory? Or should I just disable BIOS shadowing and allow the BIOS to map the 384KB as Extended and work that way? What is the best way to memory manage a 1MB 286 then?
