First post, by Kahenraz
Spotted this on eBay and found it very amusing.
167.33 KiB
Reply 1 of 8, by PC Hoarder Patrol
Kahenraz wrote on 2021-09-07, 09:08:
...on a flat plate 😀 😀 - I have a couple of these on IBM 1Ghz P3 / 133MHz slot 1s
Molex 37085 SECC2.pdf
80.11 KiB
34 downloads
Reply 3 of 8, by The Serpent Rider
Small equals noisy cooler. Can scuff crystal during installation too.
Reply 5 of 8, by Tetrium
Kahenraz wrote on 2021-09-07, 09:18:
One advantage I can see is that they are probably very light as an arrangement of fins and would pair well with a slocket.
They are indeed very light. I doubt these will cool very well though.
Btw, these 'heat sinks' can be taken apart, those fins are not a single mass but it is kinda folded together and it will come apart if you try to disassemble it so be careful when trying to take it apart 😜
An interesting design for sure.
My retro rigs (old topic)
Report spammers here!
Reply 6 of 8, by PARKE
A couple of Molex coolers were reviewed here:
http://www.thg.ru/cpu/20010521/cooler-20.html
and here:
http://www.thg.ru/cpu/20010521/cooler-21.html
The larger one in the first link scored ok, the smaller ones less so.
Reply 8 of 8, by Big Pink
That looks an awful lot like the heatsink in my Deskpro EN SFF - see Ancient Electronics' photos https://ancientelectronics.wordpress.com/2014 … ll-form-factor/
I thought IBM was born with the world
