First post, by scroeffie
hi i got a 486 and the mouse is working in the ami bios but not in game
what am i doing wrong .i installed ctmouse than reboot nothing happens
You have a bad command... where did you copy CTMOUSE.EXE to?
at A: i type in ctmouse.exe than in said installed at com etc etc
not shure what you mean by copy
When you typed ctmouse.exe then it ran it from your floppy drive (A:) and found a mouse on COM1 (your serial port), and installed itself there. But it doesn't mean 'install' as in copied the program to your hard drive so you could load it after rebooting, just that it was now watching your serial port, until you rebooted.
When you rebooted your autoexec.bat tried running c:\ctmouse.exe, which didn't exist. So you need to copy ctmouse.exe to C:
(something like copy a:\ctmouse.exe c:\ )
Might be nice to put it in a directory to stop C:\ getting cluttered.
oke wil try
Just a note regarding ctmouse. On my rig for whatever reason, with Descent2 voodoo exe, it does not recognize mouse. Had to use the regular MS mouse.com. Not sure if anyone else has ever had this happen, or if it affects any other dos+3dfx games .
oke its working now the way snufkin explains makes sense to me 😀
i also have a real microsoft mouse does it work with ctmouse drivers ?
i found my childhood 486 case in poland someone of facebook sold is to me for a good price
only thing is missing is a soundcard ,now back in the day we did not have a soundcard to expensive played games via pc speaker wich is fine
maybe a adlib clone would be nice
thinking on what kind of soundcard to use ,i have a pro 2 or maybe buy a adlib clone
That's a fine collection of floppy emulator'd systems
scroeffie wrote on 2021-09-08, 16:58:thinking on what kind of soundcard to use ,i have a pro 2 or maybe buy a adlib clone
You have a lot of goodies there!
