First post, by NyLan
Hi there,
I'm setting up a rig with a Shuttle mobo HOT-591P. ( It's a Baby AT - Super Socket 7 Mobo with a K6 266Mhz at the moment )
I've updated the BIOS to the last version and I've been using an IDE to Sata adapter to use a 2.5" SSD Drive.
To achieve this I've been using this card with its IDE connector : ( VIA VT6421A )
The attachment 2021-09-09 23.42.32.jpg is no longer available
When the computer starts, after POST the "bios" of this card is displayed and then it boots from SSD.
And it performs very well !
The attachment 2021_09_10 09_28 Office Lens.jpg is no longer available
However... if I connect the card directly to the SSD with a SATA cable.... nothing happens. The "bios" of the card doesn't show up and I'm getting an error stating there's no way to boot. ( usual message ) and Fdisk says "No fixed disk"
So... I bought the same card but without the "optional" Raid feature... twice. ( VIA VT6421A )
The attachment 2021-09-09 23.43.04.jpg is no longer available
The attachment 2021-09-09 23.43.15.jpg is no longer available
Now it's even worst ! These cards don't do anything. I mean, no bios showing up, no boot possible, Fdisk says "no fixed disk"... with both IDE and SATA
I tried to give a shoot with a FastTrack (Raid) card :
The attachment 2021-09-09 23.42.47.jpg is no longer available
It works ! But I need to build a raid.
For my last try I used a SIL3114 Sata Card which also includes a raid bios...
And it works + boots directly without having to create an array... but this card is really crappy under windows98 - the drivers is not working well - so I don't want to use that card.
My conclusion based on observation :
All cards without a RAID Bios don't work at all.
The Card with IDE+SATA AND a Raid Bios works.... only using IDE.
Cards having SATA only connectors AND Raid Bios work.
I don't have any SATA only cards without Raid Bios to test
But I've NO Idea why this is occurring. I'll try to use them on another Mobo later this week.
In the mean time, if someone has an idea, that would be great 😀
Thanks !
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 1 of 2, by NyLan
The last card of the test ( sil3114 )
The attachment 2021-09-10 09.43.56.jpg is no longer available
Personal GitHub
Reply 2 of 2, by NyLan
Ok, for some reason the FastTrack S150 is not working that well.
I mean, as soon as I install the Windows98 Driver, it crashes during win98 loading. After few attemps Windows shows an error saying the driver is not working fine and windows won't try to load it anymore.
I'm a bit surprised, I've been told this card whould work well with Windows98
Anyway, my last try will be another card I bought 😀, a Promise FastTrack 100, IDE Only :
The attachment ft100(3).jpg is no longer available
If it's not working I'll stick with the one which is working fine with IDE.
Personal GitHub
