First post, by damianmcmillan
Hello all!
I have written up my experiences with a PNP type NE2000 compatible ISA network card, based on an RTL8009.
Hope this is of use to someone - there is little information available about the compatibility of this chip that I could find.
https://dmcmillan.co.uk/blog/msdos-networking … ed-network-card
Reply 1 of 4, by Error 0x7CF
There is a newly-producible card which uses a similar realtek NE2000 compatible chip, the rtl8019.
https://github.com/Manawyrm/ISA8019
New NE2000-compatible ISA network card
JLCPCB can assemble the whole thing from newly manufactured and in-stocked parts. Their SMT assembly service supports all the parts it uses, I think. It should work in an 8-bit slot.
I think the files to get JLC to assemble them are in Mr. Manawyrm's github.
Old precedes antique.
Reply 2 of 4, by Caluser2000
damianmcmillan wrote on 2021-09-11, 06:42:
Hello all! […]
Hello all!
Good suff.
Welcome to vogons.
Reply 3 of 4, by Ydee
Thank You for share, Damian!
Reply 4 of 4, by damianmcmillan
Error 0x7CF wrote on 2021-09-11, 07:30:
I wasn't aware that PCB manufacturers could, well, actually manufacture the PCBs completely...
Interestingly, having 5 of the boards manufactured including components (sans the RJ45 connection, which appears to be out of stock) was less than £50.
I will certainly consider this in future, although it certainly takes the fun out of trying to get old hardware to work properly!
