First post, by Kahenraz
I bought a collection of CPUs from eBay and all of them had bent pins, some quote severe. I was able to bend most of them back using a mechanical pencil and a lot of patience but the very worst was a 486DX-50. I do not have a photo of it but one of the pins was completely folded over at almost 90 degrees!
I was able to straighten all but two pins which snapped off at the base. The CPU otherwise looked fine and the break was clean so I decided to try and repair it.
Unfortunately, I do not have a 486 to test it in but I suspect that it will work just fine since the damage was purely mechanical.
I dare say that the repair job is stronger than any of the original pins.
Here are the results.
The attachment IMG_20210909_035644_resize_51.jpg is no longer available
The attachment IMG_20210909_030854_resize_70.jpg is no longer available
The attachment IMG_20210909_034830_resize_86.jpg is no longer available
The attachment IMG_20210911_101412_resize_27.jpg is no longer available
Reply 1 of 5, by Sphere478
Some flux and hot air might be able to level that off a little. 😀
Good job.
Btw, if you wanna know what those pins do
Here is a datasheet for a similar model
https://www.digikey.ch/htmldatasheets/product … -datasheet.html
Sphere's PCB projects.
Reply 2 of 5, by Kahenraz
I don't think you realize how hard it was to get these to stick, as there is no good way to hold the tiny pin, an iron, and solder at the same time. There is also the risk of dropping the pin into the ether and losing it forever. This is definitely good enough and is NOT something I'm worried about looking pretty.
Reply 3 of 5, by Horun
Good job ! Hope it works !
Reply 4 of 5, by rasz_pl
Kahenraz wrote on 2022-08-29, 03:33:
wise/double sided tape, third hand and a fat hypodermic needle (they come in sizes up to ~4mm)
but it would just be chasing aesthetics, if it works it works
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
