The only thing I can find that seems to really differ is how the IC performs the writes (byte-program v page-write), product ID, and some timings with how long it takes the IC to perform an operation; otherwise the OP mode selection sequences, software command sequences, etc. seem to be 1:1
But maybe it's the fact the IC writes in a completely different manner (and that I cant find any blocks in the data sheet for Software Data Protect despite the new chip saying it supports that stuff per JEDEC spec) that would throw things off... Well, it'd be ~$1.8 USD and it's going to get bundled in with some caps I need so I don't think it'd cost me too much to find out if it'll work or not.
Failing that, there's apparently a bit of work I can do via
I used UNIFLASH to save the BIOS from a working system (using the SST PH29EE010-150-3CF flash chip) into a file. Then I flashed this saved BIOS (and not the original UUD2014.BIN file) onto the 39SF010A flash chip and it worked like a charm. No "Updating ESCD ... " message anymore and therefore also no hang. Apparently, when UNIFLASH saves a BIOS to file, it also saves the ESCD data alongside the actual BIOS.
with the caveat that I can't be swapping cards around lest I make the BIOS want to reconfigure itself, but that shouldn't be too much a problem.
Win98+DOS: C3 Ezra-T 1.0AGHz / P3-S 1.26GHz, 128MB RAM, AWE64 + Orpheus + Audigy 2 ZS, Ti 4200, 128GB SD card
Win XP SP3: C2Q 9650, 4GB RAM, X-Fi Titanium, GTX 750
PowerMac G4 QS 800MHz + GeForce4 Ti4200, OS 9
PowerMac G5 DP 1.8Ghz + ATi x800 XT, Leopard
