fsmith2003 wrote on 2021-09-15, 13:37:
Thanks for the suggestions! However, I am not very well versed in the SCSI world. If I bought this cable you linked to would I then require anything additional when plugging in only the ZIP drive? Any additional terminators or anything? The high byte termination stuff is well over my head. 🤣
It's not that complicated fortunately.
The cable you link to includes high byte terminator, so that half of the bus is terminated. What that means is you need to terminate the other half (low byte) that goes towards the drive - which is no different to situation if you just had a 'regular' narrow SCSI 25p/50p connector. IIRC there's termination built into the drive, just set the terminator switch to 'on' and you're good.
