First post, by Badscrew
Got it from ebay, listed as MDA/Hercules. Would like to know more like brand or make?
Will be pairing it with my amber monochrome monitor, hope this works 😀
Reply 1 of 8, by Badscrew
looks like a Winbond clone, but by whom?
Reply 2 of 8, by Badscrew
A real winbond for reference
Reply 3 of 8, by Grzyb
Yes, looks like Winbond, a ubiquitous Hercules clone.
One of the jumpers selects the external character generator ROM, the other disables the LPT.
Nie rzucim ziemi, skąd nasz root!
Reply 4 of 8, by Badscrew
I'll need to make a DE9 to DIN6 cable now...
Reply 5 of 8, by Badscrew
The wires you see on the first photo were connected to an external switch to select between the character ROMs.
Good to know that the LPT could be disabled: I already have one on my multi-io card. Is it closed disabled or open disable, do you know?
Reply 6 of 8, by mkarcher
Badscrew wrote on 2021-09-18, 11:31:
Remember that the parallel port on MDA/Hercules cards is at port 3BC, and thus won't conflict with a parallel port on a multi-I/O card at 378. You might still want to disable the video card parallel port to avoid the multi I/O port becoming LPT2.
Reply 8 of 8, by Grzyb
In the card I have, closed = disabled.
But indeed, it probably won't conflict with the I/O card.
