First post, by SpocksBeer
Hello all,
Just thought I'd share my experiences recently with finding the right video card for my system. The system in question is a P133, 64mb RAM. Nothing special, I have faster systems elsewhere, but this is my current project and should make a nice DOS era PC.
It came originally with a S3 Trio 64V+. It worked fine, but I found the video output, when pared with the CRT I'm using (Samsung 753DFX) to be very washed out. Shadow details in dark games like Heretic were poor. This is of course a known problem with the black level of many S3 cards (see here), though I didn't realise the it affected Trios as well as the Virge series. I obtained a Diamond 4MB Virge/DX and confirmed that the S3Bright utility would change the black levels. This definitely improved things over the Trio, but it still wasn't great.
I had a Macronix MX82600 lying around, and to my surprise the image quality of this card was vastly superior to the Virge when driving this monitor. Black levels and brightness were greatly improved, to the point of being able to turn down the brightness on the monitor itself. At this point I started doing some DOS benchmarking, just using Phils scripts. Unfortunately the MX82600 turned out to be quite slow, so the search continued.
Next I tried a Voodoo Rush from IO-Data. This performed well, but the image quality was only on par with the Virge. Also, the default BIOS has a really weird looking DOS font.
Next, a Trident TGUI9440. This turned out to be the worst performer of all, also with only "OK" image quality.
Finally I found an ET6000. This turned out to be the best of both worlds, great performance and black levels like the Macronix. Success! Paired with a Voodoo1 this should be an excellent DOS gamer.
I've attached my benchmarking results, should anyone else be interested.
Happy retro!
Reply 1 of 13, by Gmlb256
Hello!
I'd recommend instead using the S3 cards for compatibility reasons. The image quality and the brightness can vary between manufactures. Of the S3 cards I have only the Compaq ViRGE/GX has higher quality components and doesn't suffer from the brightness bug.
You can check Gona's list to see which video card really works for you:
https://gona.mactar.hu/DOS_TESTS/
Reply 2 of 13, by SpocksBeer
I was wondering about compatibility. I'll fire up some of those games and see how I go, but at the end of the day I don't have unlimited resources, and finding a "good" Virge seems to be a crapshoot.
Reply 3 of 13, by Gmlb256
SpocksBeer wrote on 2021-09-20, 04:01:
One good tip for finding a good S3 ViRGE card is to stay away from the noname ones. Of the good manufactures for S3 cards I know they are STB, ELSA and Compaq (the one which I mentioned).
Currently I'm seeing two Compaq ViRGE/GX around $20 on eBay.
Reply 4 of 13, by SpocksBeer
We only live once, I guess. I'll find one and give it a go. 😀
Reply 5 of 13, by canthearu
Importance of perfect compatibility is probably a bit overblown.
If you don't like the Keen platformers, or have other computers capable of playing them well, is there a real reason to have every computer specifically designed for maximum compatibility?
Reply 6 of 13, by Gmlb256
canthearu wrote on 2021-09-20, 04:23:
Well it depends whether the OP likes these games or not, that list has some obscure games. There are other games that one could test such as Jazz Jackrabbit as I've heard on this forum that it has issues with the Tseng ET6000.
Cirrus Logic GD5446 is also a decent alternative but I mostly see noname ones and their VESA support is inferior compared to S3 and Tseng. nVidia cards are also great if one doesn't care about 15bpp and if he could find PCI ones at a low price.
Reply 7 of 13, by canthearu
Gmlb256 wrote on 2021-09-20, 04:36:
Funny enough, I got an ET6000 yesterday and I have a GD5446 on it's way to me now!
Reply 8 of 13, by Disruptor
An ET6000 has excellent compatiblity to ET4000/W32 and ET4000 itself.
And it has excellent 2D framebuffer performance too.
Reply 9 of 13, by Gmlb256
I stopped bothering with "cool" PCI cards a long time ago, just don't want any user to get disappointed on the long run. 😉
Reply 10 of 13, by SpocksBeer
Oh it's really just for fun and learning, with a side of information sharing for others. Looking at the compatibility matrix, the Macronix card actually looks pretty great, and a couple of FPS here or there isn't much of a factor to be honest.
I'm mostly just interested in how the "gold standard" (or even the cheap rubbish) cards stack up in the context of this PC, and with this monitor.
Reply 11 of 13, by AppleSauce
I can confirm , jazz jackrabbit will give you garbled graphics with a ET6000 , I think the card lacking mode X is why.
On the plus side it will produce some pretty demented graphics for a bit of fun xD
The attachment 20201229_191158.jpg is no longer available
The attachment 20201229_190817.jpg is no longer available
I've pretty much settled on using a ELSA S3 Trio64V2 DX , seems to have pretty decent compatibility while being reasonably quick.
Reply 12 of 13, by Joseph_Joestar
As mentioned earlier, the image quality of S3 Trio/Virge cards varies greatly depending on the manufacturer.
After using some no-name versions of both, I recently got a Hercules Terminator 64/Video which is absolutely superb. Image quality is excellent, and it can deliver refresh rates up to 120 Hz on my CRT monitor, in both DOS and Windows. More details here.
My retro stuff
Reply 13 of 13, by AppleSauce
Joseph_Joestar wrote on 2021-09-20, 06:19:
Very nice! , yeah I guess it depended on who made the board , there's so many no name cards that it makes sense people would rather go for one of those since they tend to be cheaper and more abundant.
The attachment S3quake.png is no longer available
