First post, by Vipersan
So ..I have enough parts to build a decent windows 95 build I think.
It will use a period desktop case.
and a SOYO 4SA2 motherboard ...which has 4 x 72 pin simm slots.
Currently I have 3 sticks of 8mb fitted.
In actual fact I have 4 matching double sided sticks which could in theory add another 8mb ..but according to the manual circa 1996 the last slot can only have a single sided simm fitted so for now only 24mb 70ns.
The CPU is a 486 DX4-S
and that's as far as I've got.
Time to consider slot options.
This mobo has both ISA and PCI so I can mix and match.
There is 1 x VLB socket so I could use my TGUI9400Cxi Vesa Local Bus VLB video graphics 1mb
or another card I'm considering is a fully populated Diamond Stealth 64 PCI.
Choices Choices...which way would you go ?
