First post, by theelf
Hi, first sorry my english
I buy a 210CS for cheap, and is "working" good, exept not boot, i just get a cursor blinking after bios boot
The bios and memory post is OK, i can enter bios, options are saved, and memory count is ok, but after this just cursor blinking
I tried different hard disk, CF>IDE, floppy, nothing boot. Not from HDD or floppy
I removed internal battery (are two), disable cache in bios, nothing
If at least boot from floppy i can test something, but just the cursor. I tested same floppy and HDD, CF, on a older toshiba i have (486) and both boot OK
Any ideas?
thanks
Reply 2 of 4, by theelf
Deksor wrote on 2021-09-22, 08:59:
When you removed the batteries, did you notice any sort of leakage ?
No, the laptop smell new... is in a perfect sharp, outside and inside. The batteries even have correct voltage
I was surprise the main battery... still hold charge for more than 40min!!!
I did not dissaembly more than just remove the keyboard and check anyways
Reply 4 of 4, by Nexxen
Could you post BIOS page pics?
HD as EIDE or different option?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
