First post, by Kahenraz
I was looking over a recent purchase and spotted this. The pin is still springy and not too badly damaged so I should be able to clean this off with some vinegar and a good a scrub.
The attachment IMG_20210923_132745_resize_22.jpg is no longer available
Reply 1 of 11, by kixs
Recently I had one like that and it just snapped right off when I tried to remove the green stuff. Be patient and slow 😉
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 2 of 11, by Kahenraz
First impressions were good but this board no longer functions properly and has some kind of short across an IRQ line. It manifests as a key being held down, causing keyboard detection to fail and a constant beeping sound from the PC speaker at boot. The IRQ LED flashes in sync with the speaker beeps which is why I think it's a short across an IRQ line.
Pins around the general purpose I/O chip move when pressed with the tip of my multimeter probe so there may be a loose or intermittent connection there. This may or may not be related to the keyboard/IRQ issue.
See here for a video of the boot process:
https://youtu.be/LGTIjwCxZcc
This follow-up is to warn others to inspect and test your used purchases thoroughly while still within the return window.
The attachment IMG_20210923_234225_resize_71.jpg is no longer available
The attachment IMG_20210924_002454_resize_88.jpg is no longer available
The attachment IMG_20210924_002633_resize_59.jpg is no longer available
Here is how one of the boards was shipped to me.
The attachment IMG_20210902_004339_resize_47.jpg is no longer available
Reply 3 of 11, by Kahenraz
More corrosion found after further inspection under a microscope. This is not easily seen without magnification due to the location and subtle coloring next to the white plastic of the PCI slot.
The attachment IMG_20210924_004743_resize_94.jpg is no longer available
Reply 4 of 11, by canthearu
Spray contact cleaner is your retro friend. Get some, use some, love some 😀
Going for an old motherboard without my contact cleaner is like going to work without clothes on!
Reply 5 of 11, by Kahenraz
This board has more problems than just oxidation on a couple of pins, as manifested by my ability to move some of the SMD pins just by pressing on them with my probe.
You're right that I need a good contact cleaner kit. I was able to remove some of the corrosion from the ISA slot with vinegar but a good kit will also provide a protectant to apply afterwards.
I cleaned the board with soap and water but this only minimally improves any surface corrosion which may require some careful scrubbing with an abrasive material.
Reply 6 of 11, by canthearu
Kahenraz wrote on 2021-09-24, 05:01:
Well, that is definitely nasty and definitely defective!
But yeah, for an otherwise working board, contact cleaner can mean the difference between everything working well, and hours of frustrating troubleshooting.
And sometimes, you have to replace 3 PCI slots on a motherboard to get it working right.
Reply 7 of 11, by Kahenraz
I really don't want to replace any of the PCI or ISA slots if I can help it since this is extremely invasive. I also don't have any spare slots on hand.
Replacing any of these slots sounds miserable. There are so many pins.
Reply 8 of 11, by canthearu
Kahenraz wrote on 2021-09-24, 05:33:
Yep, you need a desoldering station for that job. And I got the slots from desoldering it out of a donor board (dead un-noteworthy motherboards)
It is definitely a miserable job.
But worth it to save an AMD Slot A motherboard that would otherwise be largely useless.
Reply 9 of 11, by Kahenraz
I have a desoldering gun but they aren't always successful completing their one job.
Reply 10 of 11, by retardware
I wonder about the climate this was stored in. Must have been very corrosive. Board looks thoroughly rotten.
I'd cross myself and throw it back where it came from.
Reply 11 of 11, by AlexZ
This board is not worth saving in my opinion. Too much trouble.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Athlon 64 3400+,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2 ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
