First post, by aspiringnobody
Hello all,
I've got the same Dell HD 7570 that Phil used in his low-profile roundup here: https://www.philscomputerlab.com/low-profile- … o-cards-xp.html
I can't get the drivers to install -- it looks like the subsystem IDs don't match in the installer. I was able to force the driver to install using window's pick a driver from the list option, but this doesn't get the Catalyst Control Panel installed or set up any of the extended features. I know Phil was able to get the 14.4 drivers to install -- so there must be a way to do it! Can anyone walk me through what I need to edit in the drivers folder to get it to detect the card and install the drivers?
I checked dell's website for drivers for this card and it seems there aren't any XP drivers for this model. It must have been released after dell stopped supporting windows XP.
Thanks for any advice. I've been having really bad luck with part compatibility recently so I'm hoping I can make this card work somehow.
Reply 1 of 4, by Styler
What is your full device/subdevice IDs?
Reply 2 of 4, by aspiringnobody
Styler wrote on 2021-09-25, 10:29:
Vendor: 1002
Device: 675D
Subsystem: 2B201028
Revision: 00\4
Reply 3 of 4, by Styler
Try this one, should work . At least device ID is uniformed for HD 7500 series.
Here is (14.4) but you need to change/remove subdevice id in INF file.
Another older driver from official DELL support page
Reply 4 of 4, by theshinyknight
Styler wrote on 2021-09-25, 18:43:
How do you actually do that?
I got a Dell with the same exact card and I have the 14.4 drivers package, but not sure how do you change the inf file. Thanks
