First post, by Hezus
- Member
I've got this LCD display (note that the LCD display did NOT come with the motherboard or AT case that I'm currently using!)
The problem I'm facing is that my motherboard has a 2-pin header for the Turbo Switch and a 2-pin header for the Turbo LED. As you can see from the diagram the LCD Display expects a 3-pin IN connector with the labels 'TGN'. Is there a way to wire this up to my motherboard? I've found some threads about this, but none with a proper solution how to go about this.
I expected T (turbo?) to be +, G (ground?) to be - and N (normal?) to be + but I also see L (low), C (com), H (high) so maybe this requires some logic from the motherboard?
I do not intent to use the Turbo LED, so maybe there's a way to abuse that to signal the LCD display?
Visit my YT Channel!
