Graphics card for Pentium III 1ghz
First post, by cyrixmediagx
What would be the best graphics card for Pentium III 1ghz system? 3dfx price on ebay is too expensive. Preferably solid in dos and win9x/Me games but no slouch at later releases either.
Reply 1 of 55, by igna78
The best choice is always expensive even if it's not called 3dfx 😅
Do you want something cheap and very compatible in DOS and Win9x? The answer is GeForce FX5200 😉
Reply 2 of 55, by Joakim
Best is relative especially on a budget. A gf2 would be period correct I suppose.
Reply 3 of 55, by The Serpent Rider
GeForce 4 Ti
Reply 4 of 55, by BitWrangler
Ima say gf3 just because nobody else did 😜
but they're all good dogs Brent.
Reply 5 of 55, by cyrixmediagx
1- Geforce FX 5200
2- Geforce 2
3- Geforce 4 Ti
4- Geforce 3
Wow. That's 4 different cards. Apart from Geforce 2 which is period correct, how about other cards, should I be concern with bottleneck?
Reply 6 of 55, by Joakim
The FX is probably fastest. The reason why we all say GeForce is that you mention DOS compatibility I recon.
Reply 7 of 55, by bloodem
Joakim wrote on 2021-09-26, 17:34:
Uhm, no it's not, unless it's a 5200 Ultra. GeForce FX 5200/5500 (even the 128 bit versions) will be destroyed by a GeForce 4 Ti or a GeForce 3. I thought that was common knowledge already. 😀
cyrixmediagx wrote on 2021-09-26, 17:20:
1- Geforce FX 5200 2- Geforce 2 3- Geforce 4 Ti 4- Geforce 3 […]
1- Geforce FX 5200
2- Geforce 2
3- Geforce 4 Ti
4- Geforce 3
The GeForce 3 and GeForce 4 Ti will be bottlenecked by the Pentium 3 (in many instances even at higher resolutions)... but that's not necessarily a problem.
The GeForce FX, besides being slower, requires newer drivers which are in and of themselves slower, particularly on older hardware. But if you can find one cheap (free), and if it's the 128 bit version (don't even touch the 64bit crap that's out there), then it would be a decent performer, more than enough for most Win98 games, even at higher resolutions.
Personally, without worrying about the cost, I would go with either a GeForce 2 GTS/PRO/Ti or a GeForce 3 Ti200 as a pair for this CPU.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 8 of 55, by Joakim
Mm yeah ok I never owned an FX, they seem quite bad.
I like the quadro 2 pro I have in a very similar system.
Reply 9 of 55, by Joseph_Joestar
bloodem wrote on 2021-09-26, 18:00:
PixelPipes benchmarked the FX5200 Ultra in this video and it loses to a GeForce4 Ti4200 most of the time.
On topic, I'd go for a Ti4200 if you can find it for a decent price. If not, a 128-bit MX440 can do a decent job for Win9x games. Not so much for anything made after 2001 though.
My retro stuff
Reply 10 of 55, by pixel_workbench
Geforce2 gts or Gf3 ti200. With Nvidia, you want cards that can use a wide range of drivers earlier than 45 release, because newer drivers tend to break compatibility. Also the FX series doesn't have texel center adjustment in the control panel, so some games will have blurry text and UI.
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 11 of 55, by RandomStranger
The Geforce 4 Ti would probably be bottlenecked at least in some circumstances. Though you'd rather want some GPU bottleneck than CPU bottleneck.
Maybe with a Geforce 3 Ti200 or Radeon 8500LE would be more balanced.
Geforce MX440 128bit on a budget. Nothing beats that card (on a budget).
Actually, the FX5200 is the slowest.
Reply 12 of 55, by Sombrero
RandomStranger wrote on 2021-09-27, 05:38:
In this test, FX 5200 with 64bit memory bus is somewhat faster than Geforce 2 MX 400. The one with 128bit memory bus is somewhere between Geforce 2 GTS and Geforce 3 Ti 200.
Reply 13 of 55, by RandomStranger
Sombrero wrote on 2021-09-27, 06:04:
I don't own a Geforce 2 GTS, but in my own tests the FX5200 128bit was soundly beaten by a Geforce 4 MX440 128bit which should be around the same performance. The Ti200 was also around 50% faster.
I'm planning to make a bigger test with most of my 3D accelerated graphics cards up to 2002 in Windows 98.
Reply 14 of 55, by Sombrero
RandomStranger wrote on 2021-09-27, 06:23:
There are models with different clock speeds of FX 5200, in that test I posted the slowest FX 5200 64bit bus 333MHz RAM does get beaten soundly by Geforce 4 MX 440, but it is still faster than Geforce 2 MX 400.
There's a model of FX 5200 on that test with 128bit bus and 500MHz RAM and it seems to be on par with Geforce 3 Ti 200.
Reply 15 of 55, by igna78
@cirymediagx
as you can see there are many opinions and many advice, each well thought out according to general or personal experiences.
I believe that for your choice, you must first answer a few questions:
1. what do I want to play?
it makes a difference if you think of using DOS games and the first Win9x era compared to DOS games and the whole Win9x era: the two cases want different CPU, Video Card and maybe Sound Card (and I won't go into the details of all-in-one machines, like those by Phil) and all this means different costs
2. How much do I want to spend?
and here I refer to what has already been said above: it is one thing to want the top of the range (eg GeForce FX5950 .. I think we all agree that it is the most performing card with support for DOS and Windows games .. or maybe not do we agree? 😂), it is one thing to choose a card to play with at a decent resolution, a decent frame-rate, without asking for a loan to buy it 🤣
Given these answers, it will be easier to choose.
Then to all this we add the driver problems, hardware compatibility and everything you want, but that is part of the fun (what a satisfaction in fixing the problems and finally being able to play ... until the next system crash) 😉
Reply 16 of 55, by RandomStranger
Sombrero wrote on 2021-09-27, 06:48:
It's extremely rare, I've never seen one. Though even then it should be very circumstantial to catch up to the Ti200. It takes a 5200 Ultra to reliably do that in 1024×768. An Ultra is probably much easier to find than a regular FX5200 with 500MHz memory.
Reply 17 of 55, by bloodem
Joseph_Joestar wrote on 2021-09-26, 20:11:
Indeed, I actually wanted to say the "5600 Ultra" 😀
Reply 18 of 55, by The Serpent Rider
FX5200 aren't interesting in any capacity. GeForce FX 5600/5600 Ultra - sure, good cards. If motherboard has AGP4x - Radeon 9600 Pro/XT cards are also solid choices.
Reply 19 of 55, by NostalgicAslinger
I use a GeForce 4 Ti 4200 128MB in my PIII 1GHz@1,1GHZ machine.
