I would definitely recommend PIII 600. 450 would be ok for a single Voodoo 2. I'm running my PIII 1Ghz downclocked to 750Mhz due to 100Mhz bus - this is also an option for you.
There is also Coppermine Celeron 1Ghz with 100Mhz FSB. There were 800 and 900Mhz versions too. Another option is to buy Coppermine Celeron 566-633 (66 FSB) and overclock it to 100Mhz FSB. If you buy a few of them (they are very cheap, nobody buys Celerons) there is very good chance they will run at 850-950Mhz if your board allows setting 1.75V voltage (standard for 1Ghz PIII).
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
