First post, by andreja6
I am having a weird problem on my 486 that nobody else seems to have.
I have an ESS AudioDrive 1868F that my CD Drive connects to using the IDE header. When I don't install windows, everything is just fine. But once windows is installed, it runs slower than you'd imagine possible. It's terrifying.
It takes more than two minutes for it to finish, and the end result is always the same, it finds the CD drive, big whoop.
Has anyone else experienced this? I don't have any other sound cards I can use to test.
