Screen Scraping
First post, by anon_mribbons
Hi,
Just looking at some options here - I'd like to use DOSBox for screen scraping with legacy apps, is there currently support for this?
Regards
Reply 1 of 4, by DosFreak
Not sure what you mean by screen scraping in the context of DosBox since the term has many different meanings depending on usage. Do you mean screen capturing? If so then if you read the README then you may find something....
Make your games work offline
Reply 2 of 4, by anon_mribbons
I mean getting hold of the underlying character buffer, not the visible pixels.
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
uhm you can use the debugger (look for it in development forum)
and do a memory dump of a certain area (for example the videomemory)
Water flows down the stream
Reply 4 of 4, by anon_mribbons
Thanks QBix, you'll be hearing a lot more from me if I go ahead with it : )
Regards
