First post, by khyypio
- Member
I want to do a full recap for this motherboard, especially since the previous owner had already done couple of questionable cap-swaps. I mean look at this, very shoddy! Instead of properly mounting them, he/she just cut of the legs and soldered new caps on them:
The caps he/she used are 2000 uF 10V and 100 uF 35 V. The thing is, I think the real values should be 2200 uF 6.3 V and 100 uF 25 V. However, I can´t be certain so I´m asking if someone here has this motherboard and could check these two caps circled in the picture?
