First post, by llm
started as a UniVBE question but morphed into a VESA Info Question
Re: Do anyone know how UniVBE detects that its already loaded?
Reply 1 of 5, by _Rob
DOSBox-X 0.83.18 with default machine type
8.16 KiB
DOSBox-X default machine type
DOSBox-X 0.83.18 with vmemsize=16
8.3 KiB
DOSBox-X vmemsize=16
DOSBox-X 0.83.18 with machine=vesa_oldvbe
7.61 KiB
DOSBox-X machine=vesa_oldvbe
DOSBox-X 0.83.18 with machine=vesa_oldvbe10
7.61 KiB
DOSBox-X machine=vesa_oldvbe10
DOSBox-staging 0.77.1
5.33 KiB
DOSBox-Staging
Reply 4 of 5, by _Rob
With the fixed binary posted by @Falcosoft, it now renders much better on DOSBox-X and -staging.
Is it normal that the init signature is still VBE2 when emulating VBE 1.2 or 1.0? And should it still probe for VBE2 when the VbeVersion is not at least 0x0200?
Here is a screenshot of DOSBox-X 0.83.18 with machine=vesa_oldvbe10 and vmemsize=16
10.78 KiB
DOSBox-X vmemsize=16 machine=vesa_oldvbe10
Also note how regular DOSBox and -staging both return 0 for capabilities while -X returns a different result.
