First post, by HanJammer
- Oldbie
I bought A2620 for my A2000 - card works OK, passes RAM test, CPU works OK. Problem is it won't boot from HDD. It doesn't even see the HDD controllers (A2091 and Buddha) are installed. When I switch back to 68000 via right-click menu it will boot just fine.
Kickstart is 3.1. Machine has 2MB of Fast on A2620, 2MB of Fast on A2091 and 4MB of Fast on 3-State memory card (more memory is populated on the card, but I can't use it after installing the A2620). It seems A2620 has latest Rev 7 ROM (but I'm not 100% sure it does).
I know A2620 has a jumper to allow Amiga Unix autoboot, but I don't think it's necessary for Amiga OS.
What I'm missing here?
